Question about Microsoft Windows XP Professional
Hold which key to enter bios toshiba satellite
    Novelist:
  • 187 Answers
Usually the PF keys at top of keyboard and try PF2 first, if not work, try PF8, then PF11, then PF12. but you have to use them when you are in the boot up phase before you see Windows logo opening. hit the key when the pc is starting up.. usually you can see the PF keys displayed at bottom of screen during the boot up(startup). one might say Boot or BIOS, which ever does that is the key to press.
keeping pressing it over and over when you see it, immediately. if the WIndows logo starts showing it is too late and you have to shut down and try again until you get the key to work.
Posted on Dec 27, 2015
How to do i enter bios setup in toshiba 5205-s705
Hold down the F1 key, then, while continuing to hold it down, press the power switch. the system will turn on, then prompt you to check system and press F2 (thats from memory, it maybe F1 again) to enter BIOS.
With many Toshibas you can hold down any key to do this, as it simply generates a keyboard error, prompting the same message.
Hope this info helps.
May 19, 2012 | Toshiba Satellite 5205-S705 Notebook
I turned off Hard drive and DVD drive in Bios on Toshiba Satellite L455D-S5976 now it wont come on what to do?
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
May 17, 2012 | Toshiba Satellite L455DS5976 Notebook
I have a Toshiba Satellite A135-S2276 notebook. I've downloaded BIOS update for Satellite A135-S2276 ( v1.6, v1.4, v1.3, v.12, v.1.1) from csd.toshiba.com but I can't flash the bios. It just pop up error...
F2 key method Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
Toshiba Hardware utility method Run the Toshiba Hardware utility from the Toshiba Console. It may also accessible (as 'HWSetup') from the Windows Control Panel. Changes to some of the settings will require re-starting the computer. This method is the only way to access the BIOS settings on some notebook PCs (Satellite 5000 series, for example). (For these machines, pressing and holding the F12 key immediately after powering-on the notebook will allow you to alter the notebook's boot priority.)
If the Toshiba Hardware utility is not present, try the F2 key method and the Esc key method (see below). The Toshiba Hardware utility may be downloaded from the Toshiba support website at //support.toshiba.com
If the computer is fully off, and/or to avoid having to re-start it (and Windows), use one or the other of the following two methods. The PC will have to be truly off (not suspended, or in standby mode, or in hibernation mode). If an external keyboard is attached to the notebook (either directly or via a docking station or a port-replicator), disconnect it until you have completed this procedure.
Esc key method Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
Feb 09, 2018 | Toshiba Satellite A135-S2276 Notebook
Satellite 230 how do u get into bios
Turn the computer off.
Hold down _ANY_ key, and keep it held down.
When you see the "keyboard error, press BLAH to enter BIOS setup", just press the 'BLAH' key.
Or:
turn the computer off.
Try repeatedly-pressing DEL or F1 or ENTER or F2 or F10, as soon as you've turned it on.
Apr 16, 2010 | Toshiba Satellite U405D-S2852 Notebook
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
Setup
I think in all bios at boot start up you press delete
Oct 07, 2008 | Computers & Internet
Entering the bios
There is 2 way to enter, you can use Toshiba HW setup for BIOS setting from windows. Alternately you can hit ESC several times after turn on the computer and hit F1
Good Luck
Jun 18, 2008 | Toshiba Satellite A15-S127 Notebook
Default bios password toshiba satellite a135-s2276
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Jun 03, 2008 | Toshiba Satellite A135 Notebook
Microsoft Windows XP Professional Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
