Question about Retail Supplies
Verifone mp100 driver
Hello, can some help VeriFone mp100 usb driver for windows7? Thanks!
  • 6 Answers
SOURCE: Inserting Paper into Verifone Credit Card machine
I do not have a pictur eor video but it is not difficult. Open printer door, place paper in printer with the paper coming out towards the keys of the terminal from underneath the roll. Pull slacked paper over keys of terminal and shut printer door.
Posted on Aug 28, 2008
SOURCE: verifone omni 3750
Use this Master Password from the manufacture #23378463
Posted on Mar 22, 2009
hellonnnewma
  • 26 Answers
SOURCE: verifone vx610 decline code 248
This is tricky to answer... different processing service use different codes. If the software you are running is built on a St. Pete's platform, this code means that the transaction you were processing was a 'reversal' (void) and the amount entered didn't match the original.
If you were running a sale and received this code and the display or receipt actually printed "declined" - it is a valid response indicating the customer card was declined and the code tells the service rep at your processing center why it was turned down (over limit, high risk, frozen account, etc...). If the response did show the word "declined", you can call your customer service department for your processor and they should be able to tell you what the code means in their system. If they don't - change processors as this is a standard service.
Posted on Sep 05, 2009
hellonnnewma
  • 26 Answers
SOURCE: How can I solve the problem **tamper** in Verifone Vx510?
Verifone has a built in safe-guard against tampering. There are certain things that can cause the new Vx Series of terminals to display this error - from someone actually tampering with the terminal, to a physical drop or jarring of the terminal.
I hate to be the bearer of bad news, but the ONLY way for a terminal to be unlocked when displaying "Tamper" is to send it into an authorized service center. I have many of these devices in the field for customers and have dealt with this issue a few times - unfortunately, that's the only way Verifone set it up for this error to be resolved.
Sorry for the bad news, but hope it helped!
Testimonial: "I suspected that. Anyway I appreciate your attention and your cooperation."
  • 3 Answers
SOURCE: Instruction manual for Verifone Vx510?
http://www.verifone.com/PDF/guides/23216_Omni_5xxx_vx5xx_vx6xx_Installation_Guide.pdf
Posted on Feb 18, 2010
Screen display: verifone 05150 qa0010a1 07/23/2007 verix **tamper** copyright 1997-2007 verifone allrights reserved
the sensors inside are bad or bad plastic casing. call (775)358-2922 look for randy and maybe we can help you. thanks
Aug 01, 2011 | VeriFone VX510
Verifone vx 510 download needed no*go variable analog line
www.verifone.com/.../23216_Omni_5xxx_vx5xx_vx6xx_Installation_Guide.pdf
www.verifone.com/PDF/Vx510_Merchant_US.pdf
Above are your manuals, below is the Verifone website, use the support link to contact them, and ask for whatever you need.
http://www.verifone.com/technical-support.aspx
below is the USB driver.
http://verifone-usb-driver-installer.software.informer.com/3.0/
Dec 17, 2010 | Office Equipment & Supplies
How do I reset the time on a VeriFone 3730 omni510? It did not change with the spring time change. Thanks for your help
Simultaneously press [F2] & [F4].Key in 1, Alpha, Alpha, 66831 and press [Enter].Key in the Year, the Month and the Day and then press [Enter]. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered. Use the down arrow to scroll down to check/adjust the time.y in the hour, using military format (ex: 3 p.m. = 15), then key in the minutes and press [Enter] to complete and return to Menu 1. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered.Select Restart [F4].I hope this help don't forget to rate this post : - )
Apr 19, 2010 | VeriFone Omni 3700
Command packet for calibrating verifone omni 7100
Hello Again,
What you need is the developers kit from Verifone. That includes all coding and compilers including calibration docs that you are looking for. Call Ken Elderts (951) 775-9099
Ken_Elderts@verifone.com tell him you need the programmers kit and he will either get it for you or help you get a hold of the right person at Verifone let him know you talked to Harris from US Merchant Systems.
Try this as well.
http://www.verifone.com/PDF/guides/23431.pdf
What type of application is this for POS, retail, rest, medical, automotive? Give me a call when you can. Thanks
510-415-6119
Jul 20, 2009 | VeriFone CR 1000i (P10300101) MICR Reader
Just cant get it to print the receipt...
You can connect it two(2) ways...
1) use a standard serial cable (printer cable)
2) purchase a USB-to-Serial adaptor and plug it in to an open USB port.
Either way, once it is connected the system should see it and assign a generic printer driver.
Hope that helps! Good luck!
Jul 06, 2009 | VeriFone 900 Printer
Drivers for a verifone 250 printer in winxp
You can try to find it at this link
http://verifone.50webs.com/
Dec 18, 2008 | VeriFone 900 Matrix Printer
Verifone 350
If you are using the PrintPak 350 printer, you can use either a standard serial printer cable to connect to your computer, or use a serial-to-usb adapter cable to plug it into an open usb port. Once plugged in, your computer should assign a Generic printer driver to the device automatically.
Aug 09, 2008 | VeriFone 900 Printer
Verifone 1000 se
The Verifone 1000se uses a special serial cable that also has to provide power to the device. It does not use either ethernet nor usb.
Mar 31, 2008 | VeriFone PINPad 1000SE Network Terminal
Retail Supplies Logo
77 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Are you a Retail Supply Expert? Answer questions, earn points and help others
