Question about John Deere Garden
3038e will not start
Makes 1 clicking sound & nothing happens battery is good all lights & gauges work.
johnny_20
  • 161 Answers
SOURCE: honda civic wont start
You might have to change the spark plugs or at least have them cleaned.
Posted on Jul 12, 2008
  • 92 Answers
SOURCE: Battery good, wont turn over, just a click when try to start
it is most likley starter relay or starter.with vehicle in park and e-brake on have someone tap on the starter with hammer while your trying to start.if starter starts to crank then you know the starter is on the way out.if starter does not crank it may already be shot.srarter relay is on fire wall check power + ground.
Posted on Oct 26, 2008
  • 99 Answers
SOURCE: 2004 Kia Rio Won't Start Clicking Noise Battery is GOOD
Sounds like the starter.
Posted on Jan 22, 2009
  • 3197 Answers
SOURCE: Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Posted on Apr 05, 2010
  • 1403 Answers
SOURCE: my 2004 pontiac grand prix gt wont start when i
if you turn headlights on and turn key to start do you hear clicking? if so starter is possibly bad,lets trouble shoot your problem.suggest you check the fuses under hood in black box,make sure those are good. when you turn the key, you should hear at least a click or else the starter is not drawing current.try turning the headlights on and at same time turn the key and try to start, if lights go dim the starter is drawing current, does it click? if so then bad starter. if no noise at all,,still could be a bad starter.suggest that you remove the starter and have it checked out.also make sure the car is in park for sure before you do any of this. hope this helps!!
Posted on Sep 13, 2010
1995 Ford Escort Wagon, turn on the key NOTHING happens. No click no dash lights no start.
Buy your battery there is a master fuse link that burns out to protect the systems. It is a smaller section of wire Lighter gauge that burns and separates. feel for it and look for bubbled wire coating.
this could be your problem and is a simple fix. Mike
May 26, 2016 | 1995 Ford Escort Station
Cannot turn but has ignition light on.
Battery terminals OK??? Battery OK??? Check for the fuse and circuit breaker for iginition.
Mar 21, 2014 | Toyota RAV4 Cars & Trucks
I have a95firebird t a turn the key nothing happends no gauges work on the dash nothing lights up but it has a good battery
Make sure the battery terminals are clean! I can't believe GM still won't get off it with this design.No other company has changed to this design,and with good reason.They make jumper cables impossible,and how can you see the corrosion when it happens? Remove the 5/16 battery bolts (black first),and look at the terminal inside the boot.
Oct 14, 2012 | Cars & Trucks
1992 pontaic sunbird GT 3.1L V6 when I turn the ignition key to the position just before crank, everything seems normal for about 3 seconds, battery gauge shows full charge, gauges do their little...
SOUND LIKE DEAD BATTERY.HAVE BATTERY CHECKED AND REPLACED.MAKE SURE ALTERNATOR CHARGING BATTERY.WITH ENGINE IDLING BATTERY VOLTAGE OUTPUT AT BATTERY SHOULD BE 13.5 - 14.5 VOLTS. IF NOT CHECK ALTERNATOR BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE OR LOOSE CONNECTIONS,CHECK ALTERNATOR FUSE AND MAKE SURE ALTERNATOR DRIVE BELT NOT LOOSE SLIPPING OR BROKEN.
Jun 26, 2011 | Pontiac Sunbird Cars & Trucks
Engine do not start (no cranking), only the sound of clicking (relay??). All indicators are normal (lights up), battery good (tested by turning on headlights, blowing horn). Happens after turning off a hot...
Hi:) That sound like the solenoid is the problem it is located on the starter and if the solenoid is not working right it will do all the things you are explaining.And yes heat has alot to do with it and being ware out.If it is the original it is time to replace the starter anyways it's 16 years old.
Mar 08, 2011 | 1995 Toyota Corolla
The Jeep suddenly will not start. When the door is opened there is a clicking noise and the needles on all the gauges move to the right. When turning the key nothing happens but some clicks and movement of...
Check the battery to make sure it is good,and check the connections at the battery,remove them and clean where the terminals connect to the battery,and the battery post,until they are shining.If this is helpful,please rate,thank you.
Jun 20, 2010 | 1999 Jeep Grand Cherokee
Starter issues
I would first verify battery power, Once you have proper power there, either via a good trickle charger or battery replacement, I would check the fuseable links mounted right at the "hot" side of the starter. Just follow the 4 gauge wire from the battery to the 15mm/13mm nut on the starter. Make sure you have power to both sides of the wire with a test light. THis is the only wire that supplies the power for the relay fuse box. So either your not making power, or the power isn't reaching this box. Let me know how you make out.
Jul 12, 2008 | 1996 Pontiac Sunfire
Garden Logo
94 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
