Question about RCA HD52W151 52" Rear Projection HDTV
RCA 52" HDTV Won't turn on
RCA HDTV 52" won't turn on. Worked great for two plus years and now all I get is a light. light on power button comes on three times and turns off. no pic no sound.
  • 5 more comments
  • sarahsue Nov 07, 2007
    We have the same problem. I have tried everything I can think of. Unplugging it, holding down the button,changing channel button and now it makes a clicking noise but still wont come on
  • Anonymous Nov 08, 2007
    We started having the same problem today with this TV. Same light comes on 3 X then goes off. Must be a problemwith these TV's, you think?
  • Anonymous Nov 27, 2007
    My Kids was playing a game on the tv and now it won't come on. All I get is a flashing light for a couple of seconds, no power, no sound my son saw a green line in the middle of the tv. No pic on the screen only the green on light comes on for a minute.
  • VICTOR COGNETTI Dec 18, 2007
  • starlite5pa Feb 24, 2008
    tv takes about 30-40 minutes to turn on. after pushing the power on button on both remote and tv the green light turns on and off on and off but doesnt turn on until about 30 -40 minutes later,,,,,,,,,is very annoying. i have unplugged and waited several minutes before plugging back in, didnt help!
  • funnychick May 15, 2008
    Same problem, turn the power on and it flashes 3 times on off, on off, on off then nothing. Need help
  • abrahim64 May 17, 2008
    i have same problem,can that be fixed?
  • 1153 Answers
This set has problems with the ribbon that come from front panel back to ssb. Make sure it's on tight, pull off and reconnect. This will be the first thing to try. For more info
Posted on Jan 06, 2008
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
lighty comes on three times no picture no sound
Posted on Nov 30, 2008
the circuit board behind the power on and off button needs to be replaced very easy fix.. good luck everyone
Posted on Jan 09, 2009
  • 8617 Answers
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Posted on Jun 29, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
Tv won't turn on. It turned off after a few minutes and won't turn back on. We opened it up and replaced the fuse.Didn't change anything. A friend said that it just seems to not be getting any...
does the power light flash three times slowly then stay off? If so chances are its just the CP150, cp120 and CP114 capacitors. There is the RCA repair kit by that same name available from which has the capacitors and the CD with repair instructions
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
Problem is that tv won't power on. We get three blinks from the power light and then it disappears. Please help!
Replace the deflection board. The ITC222A deflection board PSB-260 is available from which comes with installation instructions.
Sep 26, 2011 | RCA R52WM24 52" HDTV Projection Television
Tv has been turning off right after you turn it on then after a few attempts it would stay on now the power button on front turns green, it tries to come on but then turns off.
Sounds like high voltage power supply has gone bad. You can try purchasing new PS online and replacing yourself if handy or you will need to bring in for service.
Mar 04, 2011 | RCA HD52W59 HDTV Projection Television
Check 3 capacitors on Power supply/deflection board cp150 2200uf 16v if it is bad replace 2 other caps in same circuit cp111 cp114 220uf 35v
Dec 01, 2008 | RCA D52W19 52" Rear Projection Television
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA 52" HD Widescreen
Only thing can suggest is try the bulb itself to see if it got damaged in transit.
May 22, 2007 | RCA HD52W56 52" Rear Projection HDTV
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W151 52" Rear Projection HDTV Logo
289 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
