Question about Bernina Sewing Machines
How to program buttonhole on Bernina 1090S - Bernina Sewing Machines
4 Suggested Answers
  • 1116 Answers
SOURCE: Bernina 240, won't complete the buttonhole
Double check the instructions and if there is still an issue, call the Bernina dealer and tell them what is wrong.
Ask if someone will be available to look at the machine when you come in .... you need one-on-one assistance.
Posted on Mar 07, 2010
SOURCE: got bernina 1015 sport sewing
This machine uses 'New style' snap on feet. The reason it is 'new' is because old style Bernina feet are the complete foot, whereas new style you just 'snap on' the foot base.
Ebay is the best place to find original Bernina feet at very reasonable prices. I recently purchased a solid steel 'old style' foot from UK for U.S. $28.
When purchasing zipper feet, decide if you want regular zipper foot or invisible zipper foot. Often it is cheaper to order both at the same time, due to S&H fees.
Posted on Jul 24, 2011
Testimonial: "very helpful thanks"
  • 539 Answers
SOURCE: bOBBIN THREADING ON BERNINA 1090S IS NOT WORKING
Make sure bobbin is pushed all the way to the right to lock in place for winding. You say thread cuts...Do you mean bobbin in bobbin case and you are trying to sew, but thread is breaking? If so, a whole different issue. That means there is jam and it can happen if thread not going into tension discs top of machine. Keep presser foot in up position when you thread your machine. Clean the bobbin case and feed dog area out with a brush. Always turn handwheel toasted you or you can cause imbalance of timing. Slow down. Start over after you check basics. Make sure presser foot up when you insert new needle and thread front to back--flat side needle back, more rounded side facing you, use emery cloth to carefully, gently smooth out any burrs or scratches on your bobbin case (that threaded bobbin fits into), and make sure bobbin you place into bobbin case has thread EVENLY distributed on it. Good luck! Jimmy
Posted on Apr 04, 2012
Which model old style cam type buttonhole attachment from Singer will fit on the Bernina 807 minimatic machine that is an equivalent to the singer featherweight that I can make keyhole buttonholes.
In my earlier response, you need a shank that is made for your Bernina 807 and Berninas made in that era. Only "Old Style" Bernina presser feet and adapters will fit your machine. No other brand will work, not Singer, not Janome, not Brother, nothing but Bernina Old Style. There are several Bernina old style presser feet. Look for presser feet with the number printed in black ink or presser feet that have the number stamped into the metal. Do not buy a Bernina presser foot with red numbers--will fit only newer Bernina machines.
If you want to use the Singer buttonholer attachment, it needs to be for a straight shank machine. You will need to have a Bernina shank adapter for your machine.
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." The first Old Style item is the shank adapter you would need to attach the Singer buttonholer attachment to your machine. (Am assuming it will work, no guarantees!) If it doesn't work, then you will probably not be able to use the Singer buttonholer with your Bernina machine.
This shank adapter would fit your machine:
http://www.ebay.com/itm/Adapter-Low-Shank-Feet-Foot-Bernina-500-1630-Old-Style-/380397208368
If you are looking for a snap-on adapter, it needs to state that it will work with a Bernina Old Style machine, ie the old Record machines (930 Record, 830 Record, 730 Record, 707, 807 Mini, 630 Record, and 530 Record--or in other words, Berninas manufactured prior to probably 1996).
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." If you are looking for the snap-on, go to the very last item on the page (Old Style). This will fit your machine. Remember, if it says Old Style, it should work on your machine.
This snap-on shank will fit your machine:
Presser Foot SNAP ON SHANK Adapter Bernina Old Style 530 532 1630...
This presser foot will fit your machine:
http://www.ebay.com/itm/BERNINA-ORIGINAL-20-SATIN-DECORATIVE-STITCH-FOOT-OLD-STYLE-830-1530-930-etc-/132055492681
This is an entire kit of snap-on feet with shank (included) that will work on your machine:
http://www.ebay.com/itm/20-Feet-Set-for-Bernina-Sewing-Machine-Old-Style-530-1630-Models-/381790565625
Here is a kit of snap-on feet with shank (included) as well as the buttonhole attachment you were asking about:
17 Feet Set for Bernina Sewing Machine Old Style eBay
Although, I believe you will be able to make only straight buttonholes with this buttonhole attachment.
Hope this helps.
Jan 07, 2017 | Singer Sewing Machines
What model singer buttonhole attachment will fit a Bernina 807 minimatic machine. This question was asked but I can't find the answer.
Most likely a Singer presser foot will not attach to your Bernina. They are not interchangeable.
You can also probably use something like this:
https://www.youtube.com/watch?v=JOImaKwv4fU
but you need to purchase a snap-on shank adapter for your Bernina, like this:
http://www.ebay.com/itm/PRESSER-FOOT-SNAP-ON-SHANK-ADAPTER-BERNINA-OLD-STYLE-530-1630-0062617000/282290526069?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40807%26meid%3D4fe9a7b6fca84bb3adef4f466cc8776f%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D401187382421
Or, are you talking about the presser foot? Bernina #033? You can usually find a replacement through eBay, or even purchase a snap-on shank and pick up a snap-on buttonhole foot. But, if you have another zig-zag foot or open-toe presser foot, you can probably get by with using it as long as you can see your marks on the fabric when you stitch.
If you are actually referring to a buttonhole attachment like what is available for new machines, you may be out of luck. Probably not any available for this older model. The automatic buttonhole attachment usually has a sensor that your machine does not accommodate and the buttonhole attachments have a different shank that will not work on the older machines.
However, the buttonhole dial on your machine should work just fine. You just need to do more pre-work, ie measuring the button and marking the buttonholes on the fabric before stitching them. Even if the machine is only a zig-zag, buttonholes can still be done on them. Just be sure to practice a few buttonholes on scrap fabric before trying them on your garment. Get the stitch length so the zig-zag stitch has no gaps between threads but also does not overlap the thread next to it. Also, check that the tension does not cause the fabric to pucker (be sure to use a stabilizer between the fabric to prevent the fabric from stretching or distorting).
Button hole MPG (good tutorial)
807 Manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwidgJqA1rDRAhVU7WMKHbfsAfUQFggcMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FSupportData%2FOut-of-Print%2FBERNINA_807_810_817_manual&usg=AFQjCNFNJyvVESPeSjAOPQT2cX5Z3rclbw&cad=rja (pg 27-28)
Tutorial how to sew buttonholes with the BERNINA presser feet no 3 3A 3B...
Genuine Vintage Bernina Old Style Presser Foot 033 Manual Buttonhole eBay
How do I make a new buttonhole on my 1260? B
Hi Karen,
Sew two parallel lines of overlock stitches very close together. Then see overlock stitches accros the ends of the first lot of stitches to close them off. Finally, carefully cut the fabric between the first set of stitches. Try this out several times on some scrap fabric. You'll need to get the spacings sorted out.
Jul 19, 2015 | Sewing Machines
Which old Singer buttonholer fits the Bernina 807?
the bernina should have that built in as an automatic thing
Apr 27, 2015 | Bernina Sewing Machines
Bernina Bernett 55 is stuck in reverse
make sure it's not in the buttonhole setting, and if the machine
isn't in the buttonhole setting and the buttonhole lever isn't down
then it would be a good idea to have the machine checked to see
why the machine ins stuck in reverse.
Dec 13, 2012 | Bernina BERNETTE 65 Mechanical Sewing...
Bernina Buttonhole foot #3A
Difficult to say whether your current foot can be repaired or even if a new foot is the answer. I believe the auto buttonhole needs to be calibrated to the machine, but not sure that is the issue with your machine.
You can sew a buttonhole without using a buttonhole foot--not really difficult as that's how it was done for many years before the manufacturers developed the specialty foot. (My machine came with a buttonhole foot but I still make mine the old-fashioned way because I determine how they will look rather than the machine making that choice for me.)
Practice a few times on scrap fabric and write down the stitch widths & lengths that work the best for you so you can replicate each stitch to look alike.
How to make button hole
l Until Wednesday Calls How To Manual Machine Buttonholes
Manual Buttonhole Settings
How to sew buttonhole with an old machine
How to Sew Button hole tutorial (this is my least favorite method)
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
(also don't care for this type--don't like the look when the fabric is rotated and stitched across the end of the buttonhole--the bartacks on the other buttonholes is much more professional)
Sewing Buttonholes Without Buttonhole Foot
Buttonholes without using special feet or cams YouTube
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith (this creates a much more professional looking buttonhole)
Apr 16, 2017 | Bernina Sewing Machines
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
Aug 18, 2008 | Bernina Virtuosa 160
Uneven buttonhole sides
Hi, I'm a Bernina tech and can tell you you need to have a technician recalibrate your buttonhole foot to the machine. There is a function in the service program to do this. Also the machine will need a speed calibration once the buttonhole foot is calibrated. This will definatly solve the problem.
May 23, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
23 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
