Question about Lexmark Office Equipment & Supplies
900.00 Firmware Error. To continue, power off, wait 10 seconds, power on.
2 Suggested Answers
bluegreenash
  • 661 Answers
SOURCE: Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Posted on Oct 15, 2007
How do I fix error code 6202
Code 6202 To Reset. Disconnect from power source wait 2 minutes and reconnect. This should work. I believe it is a modem problem. Your manual should cover this. Contact Kodak for further problems Most issues are correctable by the user and the user should first consult the user/operators manual.
Jul 03, 2015 | Kodak Office Hero 6.1
Printer showing error code 3802
To resolve the error:
  1. Upgrade your printer firmware to the latest version:
    1. Locate and select the firmware for your printer.
    2. Follow the instructions to install the firmware.
  2. If your printer firmware is already up-to-date:
    1. Press the On/Off button on your printer control panel.
    2. Disconnect the power cable from the back of the printer.
    3. Wait 10 seconds to allow the printer to reset.
    4. Connect the power cable to the printer.
    5. Turn the printer on by pressing the On/Off button.
  3. If the error continues:
    1. Open the printer access door.
    2. Remove and install the printhead.
    3. Close the printer access door.
    4. Follow the on-screen instructions to calibrate the printhead.
      NOTE: If you are not prompted to calibrate the printhead, turn off the printer, wait 10 seconds, then turn on the printer
Feb 03, 2015 | Kodak Esp 3250 All-in-one Inkjet Printer
Why is my kodak 5250 showing error code 3807?
Error: "System status failed" (3807) Published 08/25/2010 11:38 AM ' Updated 08/28/2012 05:23 PM ' Answer ID 1249
How do I resolve the error message "System status failed" (error code 3807)?
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary
  2. Remove and install the printhead two times.
  4. Wait until the printer is ready to use.
If the error is resolved, upgrade your printer firmware:
  2. Follow the on-screen instructions to install the firmware.
If the error is not resolved, contact us.
Jul 01, 2014 | Kodak ESP 5250 All-in-One Printer
I have code error 6202
To resolve this error:
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
When the printer is ready (no error message), upgrade the firmware for your printer: the firmware for your printer.
Install the firmware from the products site.
If the error continues and you cannot upgrade the firmware, contact the product company.
Hope this help.
If u find this solution please rate me.
Jun 11, 2011 | Office Equipment & Supplies
Error code 6202
Thank you for contacting FixYa printer support. Error: "Printer error" (6202) Published 08/25/2010 11:38 AM ' Updated 05/20/2011 09:04 AM ' Answer ID 1247
How do I resolve the error message "Printer error" (error code 6202)?
If the error continues and you cannot upgrade the firmware, contact Kodak Technical Support.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
On a 7250 have error code 6202, having..
When the printer is ready (no error message), upgrade the firmware.
If the error continues and you cannot upgrade the firmware, contact us.
Feb 01, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
The printer screen freezes and i cant do nothing i have disconnected the power sometimes it work but freezes again
Please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
May 13, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
Ihave hp 2600n printer error 55.1 & i turn it off and open with out soved pls help me thank
DescriptionDC controller error. The device has experienced an internal hardware error. Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information. 55.xx PRINTER ERROR alternates with CYCLE POWER TO CONTINUE An internal communications error occurred. The page containing the error will automatically be reprinted. 1. Check the power at the customer’s location. 2. Replace the formatter and/or firmware DIMM. 4. Replace the engine controller board. 5. Replace the formatter board. On the 5si, 8000, 8100 this could be a fuser problem. Try replacing the fuser.
Apr 11, 2010 | HP Color LaserJet 2600n Printer
Information About Management Mode for Firmware Recovery
What is Management Mode? If you encounter an irrecoverable condition with the WRT54G v5, you can use Management Mode to recover the router by uploading a new firmware image. In Management Mode, the router will have just enough functionality to load a newer firmware. You should be able to recover the router is most situations. When will the WRT54G v5 enter Management Mode? The WRT54G v5 will enter Management Mode when: * The router's firmware is corrupt (for example, when the router's Power light is blinking), OR * When the router has been reset incorrectly using the following steps: 1. Unplug the power cord. 2. Press and hold the Reset button. 3. Plug power cord back in (Reset button still held in). 4. Wait about 5-10 seconds. How do I get out of Management Mode? * To get out of Management Mode, simply unplug the power cord from the back or router for ten (10) seconds and plug the power cord back in (without using the Reset button). If the router's firmware is complete and without error, the router will start up normally. If the above does not work, try: * Download a local copy of WRT54G Version 5 firmware that you can use for recovery. Visit http://www.linksys.com/download to download the latest firmware. After unzipping and extracting the firmware file, click on the Browse button from the Management Mode page, select the firmware file, and upgrade the firmware. After this, Reset the router normally (by holding in the Reset button for 10 seconds) and the router should exit Management Mode. How do I enter Management Mode manually to recover my router? NOTES: * The PC that will be used for the recovery MUST be connected to the router via a hardwired Ethernet cable and not a wirelessly connected computer. * Be sure that you have a local copy of WRT54G Version 5 firmware that you can use for recovery. Visit http://www.linksys.com/download to download the latest firmware. * In most cases, the router will be able to provide an IP address via DHCP when in Management Mode. If your PC does not automatically receive an IP address from the router, you will have to set up a static IP address for the upgrade. See Answer ID 534 for more information. * When the router is forced into Management Mode, the Power light will blink. 1. Unplug the power cord from the back of the router. 2. Hold down the Reset button. 3. While holding down the Reset button, plug back in the power cord to the router. 4. Continue to hold the Reset button for five (5) seconds. After five (5) seconds, release the button. 5. Wait for about one (1) minute. Then, on a computer connected to the router, launch a web browser (for example, Internet Explorer or Mozilla Firefox). 6. Type in the router's IP address of http://192.168.1.1 into the Address field and press the [Enter] key. 7. The Management Mode - Firmware Upgrade interface should appear. NOTE: If you accidentally enter into Management Mode, you can exit by simply unplugging the power cord from the router and by plugging it back in. 8. Click Browse and locate the firmware file. 9. Click Apply to start the firmware upgrade process. 10.Once the firmware upgrade process has successfully completed, an "Upgrade Success" message will appear to confirm that the upgrade has ended. 11. Unplug the power cord from the back of the router and plug it back in -- this will restart your router using the new firmware.
Feb 16, 2006 | Linksys (WRT54GC) Router
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
