Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
Pull out fauset is hard to pull out and return
I installed a single lever b114900 fauset i turn the water on and the water come out of shower head and fauset
I woke up to this problem this morning and was told by delta it could either be the cartridge or the check valves assembly. For me it was the check valves. The plastic developed a small crack. Very simple process to replace the parts.
Dec 04, 2012 | Delta & Single Handle Shower Faucet
Dash light comes on, looks like a fauset
That has to do with your coolant check to see if it's low.
Jan 28, 2011 | 2005 Pontiac Grand Prix
KOHLER SINGLE HANDLE FAUSET DRIPS
Replace both Kohler faucet cartridges. You can get free replacements from Kohler. Their faucets all come with a lifetime warranty.
Dec 24, 2010 | Kohler Plumbing
Took off shower head water barely comming out but have pressure from fauset
Hello
Is there a water restrictor in the shower head?A small round disc usually white or clear.
This could be clogged.
Next,take a old toothbrush and some comet cleanser and scrub the showerhead holes,this will get any hard water deposits out of the holes.
Mar 30, 2010 | American Standard Plumbing
When I turn the cold water faucet off water still runs out unless I back it off a quarter of a turn. It is the cold water valve for my tub. It is less than 5 years old. I can remove the decorative bell...
I dont know the modle fauset you have ,but it sounds like your cartridge has turned in the valve body. It should lock into place in the valve body with a tang in the cartridge and a slot or groove in the fauset body. If the whole cartridge assembly turns in the fauset it will couse this problem.
Dec 14, 2009 | Kohler Model 7202: Drain For PuristĀ® Baths...
How do i remove the cartridge from a moen pull out spayer
There is a tool for this job. Its a stem and cartridge puller made for moen fausets.PASCO makes one in my area.Ask a sales rep at a local plumbing supply.The rep should be able to sell you one ,or tell you where to get one.
Dec 11, 2009 | Moen 7437 Chateau Single Hole Kitchen...
How to repair a pegasus faucet
I was unable to aquire a spec sheeet. I didnt know the model# or name.I did find a web site that had pegasus fausets.Fausets.com I tried to down lode the specs on 1 of there fausets.They wouldnt let me.But i did get you a customer service#1800-444-5783 .I hope this helps
Dec 02, 2009 | California Faucets 1/2" Thermostatic Valve...
Very low water pressure
this is common for all new fauset. They have what is called a water saver in them. Some can be removed by unscrewing the spicket screen on the end of the fauset head. Pay close attn. to how its put together when you take it off the fauset. Look inside the screen head you should see a brass or plstic disk with a small hole in the center. You should be able to remove this but besure to put all the other parts back in the same way thay can out. Check to see if there is any dirt or grime loading up the screens and the plastic spray nestle. Clean by running water over them the oppisite way of flow. put the stopper in the drain so you dont lose and parts as your rinsing them. screw it back in place .
Sep 13, 2009 | Blanco Harvest Single Handle Faucet with...
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
42 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
