Question about Electrolux Refrigerators
Where is the reset button on my electrolux fridge?
Temperature too warm, will not lower
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Friend, thank you for your post! I see the temperature in your Electrolux refrigerator is too warm and would like to know how to reset it. May I please have your model number? The serial tag, which lists your model number, is typically located inside the cabinet, on the right side wall. With this information I can better address the issue at hand. In the meantime, please double check the temperature control. If the temperature is set too warm, set control to a colder setting and allow 24 hours for temperature to stabilize. Thank you - Z.
Posted on Apr 26, 2014
5 Suggested Answers
  • 109 Answers
SOURCE: Frozen food in fridge
Start with a total clean, vacuum and defrost. Unplug it before cleaning the motor compressor area. Make sure all the coils you can reach are clean. Plug it in and see what happens. If still the same - time to have a tech do pressure tests.
Posted on Mar 29, 2009
  • 35 Answers
SOURCE: GE gss25sgrb ss Fridge temperature control keps resetting
THAT IS YOUR DAMPER CONTROL AND IT WILL NEED RERPLACED
Posted on Jun 18, 2009
yecalam13
  • 41 Answers
SOURCE: side by side: freezer temperature fine, fridge too warm
sounds like your auto defrost isn't working. my maytag does same thing. the cooling core in the freezer is probably iced up. when it becomes solid ice no air(or very little) can pass by, leading to too little cold air reaching the fridge. you can try to cycle the temp levers(usually doesn't work) you can manually defrost the freezer. pull the cover off the back(inside freezer) and use a blow dryer. not sure how much parts are for whirlpool. hopefully this is just a one time thing. there are tests you can find to check some of the parts.like the heat element for the defroster, just search for the tests.
Posted on Jul 30, 2009
SOURCE: Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
Posted on May 12, 2010
Sharpo m160 is error code H4
Hi Zihaalsan, the link below is a user manual showing error H4 and solving the problem... Good luck......CHEERS..
http://olsonbros.com/sharp/support/pdf_trbl/trbl-arm160_m205.pdf
H4. Heat roller low temperature detection...
When the fusing temperature is lower than 150C° after 55sec from the start of warming up. When the warming up complete temperature is not reached in 30sec from reaching 150C°. When the fusing temperature is lower than 100C° after 20sec from ready start. When the fusing temperature is lower than 145C° when printing."
Cause Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality
Check and remedy Use SIM 5-02 to check the heater lamp blinking operation. When the lamp blinks normally. Check the thermistor and its harness. Check the thermistor input circuit on the control PWB. When the lamp does not light up. Check for disconnection of the heater lamp and the thermostat. Check the interlock switch. Check the power PWB and the lamp control circuit on the MCU PWB. Use SIM 14 to clear the self diagnostic display.
Mar 31, 2016 | Office Equipment & Supplies
AR-5316 copier. How can I correct error CODE 4H?
H4 00: Heat roller low temperature detection
Cause: Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality Check and remedy Use SIM 5-02 to check the heater lamp blinking operation. When the lamp blinks normally.
Feb 05, 2016 | Sharp Office Equipment & Supplies
Code h 4 in sharp photocopier model ar5520n
Description Heat roller low temperature detection
When the fusing temperature is lower than 150C° after 55sec from the start of warming up. When the warming up complete temperature is not reached in 30sec from reaching 150C°. When the fusing temperature is lower than 100C° after 20sec from ready start. When the fusing temperature is lower than 145C° when printing." Causes Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality
Aug 08, 2015 | Sharp MX-3610N Color Photocopy, Print &...
Please how do I clear the H 4 display on my Sharp AL 2020 copier machine
Content
Detail
150C after 55sec from the start of warming
up.
not reached in 30sec from reaching 150C.
100C after 20sec from ready start.
145C when printing."
Cause
Check and remedy
operation.
PWB.
Mar 06, 2013 | Office Equipment & Supplies
Error (H 4)
H4 00 Content Heat roller low temperature detection
Detail When the fusing temperature is lower than
150Cafter 55sec from the start of warming
up.
145Cwhen printing."
Check
and
remedy
operation.
PWB.
Jan 15, 2013 | Sharp AL 1631 Copier
Error message of H4-00
H4 00 Content Heat roller low temperature detection Detail When the fusing temperature is lower than 150C° after 55sec from the start of warming up.
When the warming up complete temperature is not reached in 30sec from reaching 150°.
Check and remedy
operation.
Good Luck do rate the solution if got help
Dec 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
2001 Taurus won't start when warm. Try to start it, it will try to run, roughly, then dies. Then will only turn over for awhile. After it sits for 20 minutes or so, it starts like a new one and keeps...
Sometimes a motor is more sensitive to warm conditions. When the water temperature sensor does not cool off it keeps the engine in a warm run mode which is very lean. This is how lower emissions and better fuel economy are made.
The "cold start sequence" makes a richer fuel mix for starting and running. I have not seen a dividing point where this switches from one mode to the other. IF it is say 180 water temperature degrees and your car stays above 180 degrees turned off after running, then the fuel mix will be very lean until the engine coolant loses heat.
About all you can do is put in a new thermostat of proper temperature or a lower temperature thermostat. You could flush the radiator and back flush the block so that heat loss is more efficient. You could put in a new water temperature sensor. You want to get rid of calcium-fication of the internal surface areas so the components are more like factory new.
Jul 18, 2017 | 2001 Ford Taurus
H4 error code
up.
Check
and
remedy
operation.
PWB.
May 04, 2010 | Sharp AL-1641CS Color Copier
Display H and than 4.. please solve my problem with thanks.
call sercice and tell them that there is a problem with the Heat roller low temperature detection.
up.
Check and remedy
operation.
PWB.
May 06, 2008 | Toshiba e-Studio 161 Copier Copier
When I switch on the copier display H and than 4.. please solve my problem with thanks.
up.
Check and remedy
operation.
PWB.
May 05, 2008 | Toshiba e-Studio 161 Copier Copier
Refrigerators Logo
615 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
