Question about Fortis Watches
Watch serial numbers 7217 - Fortis Watches
Cartier serial number550740MX
I have access to a Watch CSA Counterfeit Busters subscription and the serial number does not come up as a reported counterfeit.
Oct 12, 2013 | Cartier Pasha Seatimer Mens Watch W31088U2
Identify my watch with serial number
where can i find the serial number on my gucci watch 1500?
Sep 01, 2012 | Gucci 1500 Watches
How do I find the serial number on my Polar FT4 watch
Turn the watch over and look on the back of the watch near the wrist band. The serial number is the rather long set of numbers you will see there. You can't miss it. If you see what look like zeros or letter O's, they are zeros, not O's. I have the same watch, and that is your serial number.
Mar 22, 2012 | Polar FT4 Watch
HOW DO I FIND MY WATCH/SERIAL NUMBER
Usually the serial number is on the case, under the watch band, you will need to remove the band to view the serial number.
Jun 17, 2011 | Watches
Hello please help, I wish to know what year Rolex Oyster Perpetual Lady Date model 6519 was Manufactured. Thank you in advance.
This model Rolex has been manufactured over multiple years, and it is not possible to date your watch based purely on is model number. However, it is possible to date most Rolexes based on their serial numbers, which can be found stamped between the lower lugs (i.e., the lugs below 6:00 on the watch dial). You will need to remove the band from these lugs to read the serial number.
Dating the watch case of a Rolex does not necessarily date the entire watch. It is possible that a movement from another watch was placed into a watch case that is younger or older than the the movement. Like Rolex watch cases, Rolex movements can also be dated by their serial numbers, if this is a concern you have about this particular watch.
This jeweler has put together a nice summary of when Rolex watch models were introduced and which serial numbers are associated with specific years of manufacture. Once you have found your serial number, this should help you date your watch. I have no connection (financial or otherwise) with this web site, but I found the information useful and presented in an easy to understand way.
http://www.bgrayjewelers.com/rolex_information.htm
Jun 03, 2011 | Watches
Finding serial number of a Suunto Vector Watch
mcdevito75 here, Contact the Suunto Company useing the contact info supplied in the box the watch came in.
Jul 10, 2010 | Suunto Vector Wristwatch
I have a movado watch given to me by my grandmother I want to know if you could help me tell if it is real or not or if there is somewhere I could look up the serial number or tell which of the two numbers...
mcdevito75 here, Without seeing the watch, it"s hard to tell, the serial number that counts is on the movement itself, not the back of the caseing. See a small watch repair shop in your area for advise.
Jun 25, 2010 | Watches
How do I find my serial number on my bulova watch
Serial numbers are generally on the back of the watch.
You may be able to find two or three numbers on the watch.
A case number, a movement number and a serial number.Alternatively you might find a style number (which in your case is 26B44) and a serial number.
Mar 05, 2010 | Accutron Swiss Watch by Bulova 26B44
Do any Tag Heuer Aquaracers have serial numbers like "abc1234"?
Yes they do;
To see this go to the TAG web site "tagheuer.com" and select "watches".
Now select "aquaracer" and you will see a list of variations.
Jan 16, 2010 | Watches
Where is the serial number located on a Wenger Watch?
specific serial numbers are usually on the box or the reatilers tag. Caseback numbers are enough for ordering and service. These are the numbers on the back of your watch. If there is more than one number there then 1 number is the style number and the other is the serial number. For more specific info I recommend you contact wengerconsumers@wengerna.com
Oct 19, 2009 | Swiss Army Wenger Sportedge Bracelet Watch
Watches Logo
24 people viewed this question
Top Fortis Watches Experts
Jimmy Accardi
Are you a Fortis Watch Expert? Answer questions, earn points and help others
