Question about B&K Precision Computers & Internet
B&k 1601 I need a schematic because the overload keeps tripping I need a setup sequence
4 Suggested Answers
teknikgurun
  • 450 Answers
SOURCE: N73 Cellular Phone: كيفي&#...
In english please! may be i can help you!
Posted on May 10, 2010
  • 10406 Answers
SOURCE: كيف اسرق حساب الفيس ب&#160
Arabic to English translation:
_____________________________________________________________
How to steal facebook account without password I know what
Sorry, but nobody on FIXYA is allowed to help you "steal" anything.
Posted on Mar 17, 2011
  • 268 Answers
SOURCE: يكتب فلاش ارور تو فرم&#157
what is the matter
Posted on Jan 11, 2012
My fridge keeps tripping the power
Your solution is one of two things.
First is the circuit you have plugged the refrigerator is either over its limit and the breaker is tripping because it is overloaded. In this case you will have to determine what load also share this circuit and eliminate the extra loads or move the cord to another circuit which is not overloaded. Most home circuit are wired with 14 gauge and is rated at 15 amps. When the circuit gets to 15 amp and more, the associated breaker trips to prevent overload.
Second, Your refrigerator may have a short and needs troubleshooting to find the cause. To see if it is a bad circuit try plugging into a circuit via extension cord to circuit in another room receptical. The reason I say another room, when electrical installers wire circuits, you can put several recepticles on the same circuit. If you plug your refrigerator in the same circuit you had it on before then you will get the same problem, your refrigerator tripping again. If your frig trips on a different circuit then troubleshooting the cause will normally require a tech.
Good luck and hope this helps.
Oct 28, 2014 | Refrigerators
Goulds pump model BGR75 won't reset. Any tips.
If the motor runs but keeps tripping the overload, the motor is bad or the motor is under a big load. Does it pump water? If not, check the impeller and see if there is anything wrong with it. If it does pump water and the motor trips overload, the only thing left to check is the overload. Check the motor's amp draw and if within specs, replace overload. If amps are too high, replace motor.
Aug 22, 2012 | Plumbing
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Apple tv to optical audio on avr 1601
You need to assign the optical input to the video input you are using. It's under the 'Input Setup' menu.
Or use HDMI, it will output the audio thru the HDMI connection. Once again assign the input under the Input Setup menu (press the Menu button on remote to access setup menus)
Nov 19, 2011 | Denon AVR-1601 Receiver
How can i connect my i-mate jasjam to wifi network?
اخي العزيز عندي جهاز اي ميت وكان شغال النت فيه الان عندي اتصال بس ما في تصفحكل ما افوت على التصفح بيكتبthe address is not valid check address and try again
May 06, 2011 | i-mate JasJam Smartphone
Mackie 1400 overload lights on
hey Ron
use a larger ground wire it will stop the overload you may have to place it somewhere new but its the size of the wire that trips the overload feature too small and amp will go and protect itself (bigger ground better sound)
hope this helped
Feb 28, 2009 | Bob Mackie Mackie M-1400i Power Amplifier...
GENX Softwear needed
بدي تعريف سكانر من نوع genx600ومش عارف أجيبة
Apr 20, 2008 | Office Equipment & Supplies
Kenmore washer model # 110.24086200
The C1 code indicates the "instantaneous current limit" trip. This signifies problems with the drive motor, thermal protector, motor controller. Overloading the machine will cause high amps and trip the unit. Instantaneous current trip occurs if there is a current spike of 26 amps instantly at the motor windings in which the motor overload trips. check bearings for lubrication - or as stated above overloading the washer.
Sep 06, 2007 | Kenmore Elite 45986 Front Load Washer
Computers & Internet Logo
Top B&K Precision Computers & Internet Experts
David Payne
David Payne
Are you a B&K Precision Computer and Internet Expert? Answer questions, earn points and help others
