Question about Sony Audio Players & Recorders
My skateboard always rolls to the right like it is out of alignment. How do I fix it?
I need to know how to align the wheels on a skateboard
  • 20 Answers
SOURCE: How can I fix the
There are two answers to this problem:
1) The suspension on the front swivel wheels on the Cameleon are adjustable. As the child gets older (and heavier), his/her weight might effect the handling of the stroller. It is recommended that the suspension be adjusted. To do this, move the suspension adjustment forward, as it increases its strength.
2) There has been significant conversation about this problem with the Cameleon's veering if the chassis was purchased before 2007. If so, contact bugaboo via bugaboo.com. Bugaboo will ask you for your serial number, etc. to research whether it is something that is obviously defective.
If you have any further questions, or need help contacting the company, don't hesitate to contact us anytime!
strollerinfo@gmail.com
StrollerInfo
Posted on Oct 02, 2008
Inkworks
  • 87 Answers
SOURCE: OfficeJet G85xi cartirdges will not align
Could be one of two things....
1 - you may have bad cartridges (usually the color)...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...first replace color cartridge with a HP Brand cartridge
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Inkworks
866-381-0541
Posted on Nov 06, 2008
  • 6982 Answers
SOURCE: Chevy astro 1998 wheel alignment problems
Can't believe they don't have the numbers. but, not being in the business anymore, I don't either. However if you want to do something yourself, likely you can get it close by the" is it wearing and where' method, till you get the specs. Most have an excentric on the steering knuckle strut mount. Mark current position with something that won't wash off then turn excentric to move the top of the tire away from the area that's wearing, and lock it down. this changes your camber setting. If wheel is off center, center it and lock in place. sight down tire and see if one is visibly turned more in or out than the other. adjust that one first to make it reasonably straight by loosening collar on tie rod end. Count number of turns you made to the collar so you can return to original position if needed (write it down) Then measure distance between center of both tires at the front and rear of each, in the same place. The total measurement should be around one-quarter inch less at the front. If not, adjust each tire one half of the difference. Monitor tread wear after you do this and make any fine adjustments needed. Most of these do not have a caster adjustment, so don't bother with that.
I'm certain though that you will find a shop with those specs if you look a bit harder, but you may need to go beyond where you normally travel.
If your car is not wearing tires radically, or pulling badly, I would leave it alone till you find a more informed shop.
Posted on May 23, 2009
  • 59 Answers
SOURCE: alignment failed message always on
>try the steps on this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01451117&cc=us&lc=en&dlc=en&product=2512010
Posted on Sep 25, 2009
BAMOUT
  • 2478 Answers
SOURCE: front wheel alignment
Wheels are to straigten. Best to replace.
Posted on Jun 11, 2012
My Mitsubishi Lancer need wheel alignment, tell me, under what degree the wheel should be set up
castor angle 1/2 to 11/2 degrees
camber 0 to 1degrees
toe in 1/8 to 1/4
As it has to be done at a wheel alignment shop they will know the best settings. Make sure that they do the alignment on the rear first as it affects the front alignment
Jan 30, 2014 | 2003 Mitsubishi Lancer
Steering wheel tilted
This is a common problem. The last time the aligned it the may have bumped the steering wheel and when they aligned it and tightened everything back up it was off center. The next time you get it aligned make them aware and they'll straighten it up for ya.
Dec 01, 2013 | 1994 Pontiac Firebird
Rear wheel alignment
rear wheel alignment should always be done before a front end alignment as it affects the front end settings. Get onto a good wheel aligner and tell him that you want the rear end aligned first as most ignore that bit as it takes time and you are being charged for it but it is profit if they skip it because you do not know about it or do not insist on it.
Oct 31, 2013 | Cars & Trucks
Steering pulling to the left after wheel alignment
Hi Vincent, Check your tyre pressures and it correct have them re do the alignment. Regards John
Mar 07, 2013 | 2007 Toyota Dyna
How do you know if you need a 4wheel or 2wheel alignment? 2000 Mercury Cougar.
Most FWD vehicles can have a four wheel alignment performed. A 2 wheel alignment is mainly for vehicles that are rear wheel drive. There are exceptions but the 2000 Mercury Cougar is a 4 wheel alignment.
Apr 19, 2011 | 2000 Mercury Cougar
Crooked steering wheel on 2009 Pontiac G6, serviced twice, dealer says car is in alignment altho' the steering wheel appears pitching to left a few degrees, can this be resolved?
Yes it can be solved. All though your car may be in alignment how ever, they did not center the steering wheel prior to making any adjustments (it requires a little more work if you know what I mean), that's a part of the check list. You can fix by taken off the steering wheel but I recommend that you take it back and demand that they correct it. That's a prat of what you pay for when you taken in to get it aligned.
Sep 08, 2009 | 2009 Pontiac G6
Wheel alignment is off
Have the vehicle aligned at an alignment shop.
May 27, 2009 | 2000 Ford Focus
Scroll wheel stopped turning, seems to be hanging up due to an alignment problem. How can I open it to take a look inside?
If your scroll wheel turns but you don't feel the 'notches' it is most likely stripped. I've repaired my Logitech, and based on what I saw inside, I doubt that it's an alignment issue.
If it's stripped, and the hexagonal end of the wheel's axle that fits into the receptor has lost its hex shape, I have a perfect fix.
I tried gluing it, but that only lasted as long as the glue. What I did instead was remove the wheel, thread a thin rubber band through the receptor, pull the rubber band tight and then reinstall the wheel. Once tension on the rubber band was released, it expanded again, making a tight friction fit of the wheel's axle and the receptor.
Hope that helps.
May 09, 2009 | Microsoft ARC Mouse
Steering wheel turn to right, 1995 aerostar-extended
Something is wrong with the front end. Bring it in for a front end alignment (that could be all it needs) and have them check for problems with front end suspension components. There may be something that is worn out ( such as ball joints, or tie rod ends) that is causing the uneven tire wear. There may also be a problem from hitting a large pot hole, or curb, which bent something causing this. Tell the shop to NOT align the front end if they find that some components need to be replaced, as when something is replaced, you should have the front end aligned, and you don't want to have it done twice.
Apr 05, 2009 | 1995 Ford Aerostar
Wheel alignment for automobile
Hello. Wheel alignment is the adjustment of the front and rear wheels so that they are correctly inline with each other and pointing straight forward. If they point to the left or right the car will pull to that side of the road while being driven. The front wheels also need to be adjusted to ensure they are not too far forward and riding on the back of the tire, or not too far back and riding on the front of the tire. Lastly, all tires need to be checked to ensure they are not leaning too far in or out of their wheelwell, causing the tires to become prematurely bald. For most vehicles it can cost you $40-$120 depending where its done, plus any shim kits needed to adjust the wheel allignment back to factory specs. Most shops provide 2 or 4 wheel alignment, so always ensure that they perform a 4 wheel alignment. Always ask for the alignment test reports for both before and after the work is performed so you can see for yourself which were out of alignment. Pot holes, curb-hopping, railroad/railway tracks, etc. play a huge part in your vehicle alignment going bad. 4 tires on some cars can cost you $500-1600 to replace, but an alignment check every 2-4 years will only cost you a very small amount, saving you time and money.
Apr 03, 2009 | 2000 Mini Cooper
70 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
