Question about RCA Scenium M50WH187 50" HDTV
TV works for 5 min then shuts off and power light blinks green
RCA D34W20 tube HDTV Monitor works for about 5 min. then shuts off and power light blinks green about 3 times, acts like it is turning back on, then blinks a few more times and goes blank. Basically shuts off and wont turn back on for about 5 min. of sitting there. Then 5 min of picture shuts off etc. etc. Any help would be great.
    Problem Solver:
  • 19 Answers
Check your sleep mode...
Posted on Jun 20, 2009
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Aug 11, 2007 | RCA HD52W59 HDTV Projection Television
TV shuts down, power light blinks nine times
1) test the power supply: a) line cord, b) fuse c) c.breaker d) rectifier e) filter,f) switch,
2) measure the horizontal output +125Vdc
3) all other circuit +12Vdc-
4) vertical output +80Vdc
Oct 16, 2012 | RCA Scenium D34W20 34" TV
There are two green lights blinking at the bottom of the tv. where the power light is..i believe it's the opc lights. the tv shuts of it self and the two lil green light blink...we put the tv power...
The tv main logic board known as a tv Tuner signal board it is the causes and the problems.The tv main logic board,the tv Tuner signal board it is shorted and not taking in and sustance power from the tv power supply board anymore that why tv Power and OPC LED lights indication are flashing together.This main logic tv Tuner signal board that the board where that take in the tv incomming broadcasting signal wire plug into it.U must replaced the main logic tv Tuner signal bard to fixed this problems.If U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main logic tv Tuner signal board for the replacement.Tries tv unplug,replug it back about an hour later.Tv might work again for awhile though,but to fixed this problems for good the main logic tv Tuner signal board must have to be replace.
Aug 22, 2011 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Turning on TV
You may have dying power supply module, that will be the first place to check.
Please see my basic troubleshooting guide:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
Jun 25, 2010 | RCA L32HD31 32 in. LCD HDTV
Phillips 32" HDTV power light blinks green but wont turn on
the problem in the main power supply it depends of the kind of faillure but normaly to repair it not very expensive
good luck
Aug 23, 2009 | RCA F32650 32" TV
Tv shuts down after about 5 seconds
Sounds like the green CRT has a short.If you unplug the socket from the green CRT tube (the one in the middle) and power up the TV and it stays on then it will verify that you need a new green CRT.
Jan 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV Will Not Power On - Powered Off Suddenly
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
RCA Projection TV won't turn on
Ok you got you a Rca ITC222 I See ALOT of these things. To start the troubleshooting.. UNPLUG the set for a min of 30 min the plug back up. ( I have never seen this work) If the set stil fails to come on then you have a processor lockup. The first thing you can conclude if the light flashes is it is NOT a FUSE. THe sets processor has determined that a safety condition has occured and shuts it down to prevent further damage and fire. THe top cause of this include Horizontal output trasistor, flyback transformer and high voltage splitter. but There is about 25 different failures that can drive it into shut down. technicains have interface equipment that can read errors codes much like a car.
typical repairs on this set run 150 to 350... if you have to replace tubes...250 per tube +labor which runs 250 ... these set new cost 800 so unless under warrenty.. you got to determine if it is worth it.
May 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Scenium M50WH187 50" HDTV Logo
533 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
