Question about 831002/4100 4100 REMOTE START SYSTEM WITH 2 AUXILIARY CHANNELS
Avital remote works, key does not
Avital remote works to start engine, key does not work.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
SOURCE: Avital 4100 Mode Problem
The car is a 2005 Saturn ION
Posted on Dec 21, 2008
ltfrc
  • 227 Answers
SOURCE: engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
Posted on Jan 28, 2009
ltfrc
  • 227 Answers
SOURCE: cranks but engine doesn't start avital remote start
I beleive it is a pink wire for the ignition. If you can locate where it is connected this is your ignition wire. It may have worked loose under the dash.
jpk528
  • 95 Answers
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
evan89
  • 356 Answers
SOURCE: my - + made contact and i have a avital remote
http://www.avital.com/Products/Product.aspx?path=Remote%20Start%20ampersand%20Security%20System&id=5001
Is where you can find the owner manual for this (on the right hand side of page)
Posted on Mar 03, 2011
Disable timer on avital remote control
i think the engine rev needs to be turn down a little
Jul 14, 2014 | Hardware & Accessories
I have a 2007 chevy impala that has the avital 3300 remote start on it, I changed the battery in the remote and now it will not work.
OPEN THE r.control and clean keypads with contacts cleaner, see the picture attached. Any keys hit will be LED ON. otherwise proceed with the informatin above. 04276ea0-a088-494b-a91b-7103932b680f.jpg
Sep 29, 2013 | Directed 3300L - Avital 3300L 2-Way...
Avital remote start
see the picture attched. Clean the keypads with contacts cleaner. and fix it. use digital cameria or cell. any keys hit will be LED ON. otherwise proceed before mentioned. replace batteries and clean the contacts battery.
Avital 4003 with xpresskit xk09 install in a 2006 chevy silverado 2500HD gas engine. how to wire all the wires to get it working with the factory key fob.
disconnect battery remove the engine mount bolts jack up support from top remove starter and flywheel inspection cover remove mounting bolts for engine pan lower and remove oil pump suction pipe should come out then. don't forget to drain engine oil first.
Sep 12, 2013 | 4003L Avital 4003 Remote Start Module...
No lights with avital
If your vehicle parking lights are working at the switch then, the inline parking light fuse(15 amp) of the Avital unit may be blown.
Sep 22, 2012 | 4103LX Remote Start System with Two...
How do i reset my remote start car alarm avital 5303
i have a avital 7352l remote start my fob got smashed under the hood of my car still locks and unlocks car but went to use remote start and it tried to start car but it didnt then i got into my car and try to use my key and it didnt crank at all can anyone help me solve this problem?
Feb 21, 2011 | 5303L Security/Remote Start System
Cranks but engine doesn't start avital remote start
Jan 28, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Engine cranks will start fine with key remote will not start it
831002/4100 4100 REMOTE START SYSTEM WITH 2 AUXILIARY CHANNELS Logo
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
