Question about Garden
John deere l130 clutch pedal suddenly froze in off position.Mower will not move
Cannot depress clutch pedal. tractor will not move.
  • 28 Answers
Check your linkage to see if a lock pin fell out.
Posted on Jun 20, 2014
  • 11 Answers
SOURCE: John Deere LT 133. Will not move with mower in gear and clutch/brake released. A smell like hot rubber prior. Mower will engage. Thanks.
It could be that the belt jumped off the pulleys and got caught between a pulley and a belt guide,or the trans-axel seized up ,or brake was stuck while in a high gear,and burned up the belt. most likely the first reason. if it wasn't for the burning rubber smell,I would also look for a broken clutch/brake return spring .The pedal would stay down with a broken spring
Posted on May 24, 2009
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
agent91
  • 2100 Answers
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
Posted on Jun 10, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
BAMOUT
  • 2478 Answers
SOURCE: john deere L130 lawn tractor
Posted on Dec 24, 2011
Why won't my 2007 John Deere L130 turn over?
remove spark plug and see it it turn over .set Brake too
May 04, 2015 | John Deere Garden
John deere l130
Likely a bad switch. Could be one of three switches that will kill the engine when pto is engaged. First is the reverse switch, next is the seat switch ( operator presence switch), and lastly ( and least likely) is the clutch switch.
Sep 01, 2014 | John Deere Garden
John deere l130 has frozen clutch pedal
Check petal and linkage for a stick or etc. in there.
Apr 22, 2014 | John Deere Garden
My john deere L130 with hydrostat won't drive,eng is fine
did you knock the drive belt off?did you pull the lever that allows you to push it when not running?
Aug 15, 2012 | John Deere Garden
I paid for an answer and have not received one order # 318683 John Deere 110 tractor 1972. tractor started quitting under load but would start then run fine. Tractor quit while mowing and I found 2...
There should be a switch in the clutch pedal area. Usually safety starts for tractors is that your clutch needs to be depressed to start engine and you need to be seated to turn blades. Good Luck....
Aug 31, 2011 | John Deere Garden
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
How to change the Belt on a John Deere L130 with 48" mower deck? Is there a Belt diagragm that show proper routing?
Try the John Deere parts website https://jdparts.deere.com or give sullivans a call they are a john deere dealer and are garden machinery experts they will be able to explain to you what to do. you can find their contact info on their website http://www.sullivansgardenmachinery.co.uk
Sep 18, 2010 | John Deere Garden
I have a john deere L130 riding mower...while cutting the blades just quit turning...have checked the belt and the blades will turn by hand but won't engage with the switch
There seems to be a common problem with the L130. After reviewing the posts it appears that many people are having this issue. I had the same problem, it turned out to be the wires from the PTO switch at the clutch under the engine (right above the belt pully). The wires are breaking at the connection under the engine due to the vibration.
May 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
