Question about 5303L 2Way LCD Remote Start Security System
When using the key in the ignition it just clicks0engone does not start. When using the avital remote start it will start
The engine will notstart whe using the key to start the engine. When using the avital remote it does start.
4 Suggested Answers
SOURCE: Avital 4100 Mode Problem
The car is a 2005 Saturn ION
Posted on Dec 21, 2008
ltfrc
  • 227 Answers
SOURCE: engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
Posted on Jan 28, 2009
ltfrc
  • 227 Answers
SOURCE: cranks but engine doesn't start avital remote start
I beleive it is a pink wire for the ignition. If you can locate where it is connected this is your ignition wire. It may have worked loose under the dash.
2002 cavalier, ignition cylinder was changed for pass lock failure now remote start cranks but wont start. avital 4103L
Hi, ur problem is a simple one. U have a factory alarm-starter kill. The key and ecm have to comunicate. Ur alarm has a digital modual to make the ecm think its seeing the key when u remote start. Since u changed the "code"u have to reprogram your alarm interphase so it all comunicates the code.
Nov 28, 2015 | 4103LX Remote Start System with Two...
Disable timer on avital remote control
i think the engine rev needs to be turn down a little
Jul 14, 2014 | Hardware & Accessories
Avital remote start works to star engine, without the remote start it will not start.
You probably have a bad ignition switch that's why the remote start will work it replicates what the ignition switch does,or you have a coded key and had a new key made and not programed the remote start module has this code stored so it can send the car the code when remote started. What year make and model is the car?
Apr 22, 2014 | Vehicle Parts & Accessories
Avital 4103 when i push start button the ignition lights come on but doesn't start the engine
Try leaving the key in the ignition (but don't turn it) and then try. If it starts then you need to properly bypass the transponder system. If not then most likely you don't have your ignition and/or start wires hooked up properly. On many cars there is a second starter wire that needs to be connected
Feb 17, 2013 | 4103LX 4Button Remote Start System with...
Howto disable 24 hr timer in avital 4400
Remote start the vehicle; turn ignition on with the key. The parking lights will flash 4 times indicating that the timer mode has been exited.
Please note how the timer was activated by pressing the lock and unlock buttons.
When in the timer mode, the remote starter can time out or, you can shut down the remote starter with the remote and the timer mode will remain active. But, if the remote start sequence is terminated by any of the shutdowns ( ignition, brake, hood or neutral safety switch) while the remote starter is running, the timer mode will be terminated.
Feb 03, 2011 | AviStart 4400 2-Way Security / Remote...
Cranks but engine doesn't start avital remote start
Jan 28, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Engine cranks will start fine with key remote will not start it
Remote car starter problem.....?
need to know what car and model of unit you have . it is a sec. or ignition wire problem
Dec 23, 2008 | 831002/4100 4100 REMOTE START SYSTEM WITH...
5303L 2Way LCD Remote Start Security System Logo
23 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
