Question about Toro TimeCutter SS4235 - 20HP 42 Zero Turn Mower
Moter runs but mower will not respond when you try to move
It is as if hydrostatic controls are not working , it was working fine after last mowing last fall..
2 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: The lawn mower is burning oil and engine is missing.
Sounds like you may have broke the ring around the piston. I wouldn't run it again until you get it fixed. You could cause serious damage, if you haven't already. GOOD LUCK!
Jim
Posted on May 30, 2009
I have an LTX 1045 hydrostatic mower, was mowing and it just stopped and will not move. Motor is running but mower isn't moving. What is wrong?
theres two things that you can check on your cub that could cause this to happen
(1) ck to see that the towing bypass valve relief ,located in back low down below seat is not tripped , even a little , these levers are a bit tricky and might get bumped especially if you use a bagger (BTW) allways use the tow relief valve when moving a non running hydrostat tractor , or you'll end up with a non functional one fast
(2) visually ck to see that a belt has not come loose or broken , this can be seen ,with engine off and looking in thru under the front bumper ,down center of tractor .with a good flashlight
if its not these two then your gonna have to get a bit more technical in your troubleshooting
Jul 03, 2015 | Garden
Lost reverse. Goes forward just fine. It has no codes. I am sure it is not a hydro problem more like electrical. Any Ideas?
you may receive more help if you list the manufacturer, model, and details such as it is a hydrostat, engine size (18 HP or 22 horse briggs motor). also describe your symptoms a little more as in: it ran fine last week then today when I started mowing it just didn't want move in reverse, or was mowing when it just quit working.Hope this helps.
Jun 22, 2015 | Garden
Riding mower no longer moves.
If this is a hydrostatic transmission, one of 3 things:
1. Drive belt off pulleys (recommend replace belt if so)
2. Belt broken (obviously, replace)
3. Hydrostatic transmission failed (least likely, but this is an expensive repair shop issue if so)
This happened to my GT1554 two weeks ago - fortunately, replacing the belt resolve the problem.
Oct 19, 2012 | Cub Cadet Garden
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
I have a L118 John Deere mower. When cold, the mower moves forward and reverse without problems. I mow my 1/2 acre yard and at the last couple passes, the mower barely moves forward and has no reverse. ...
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
May 23, 2011 | John Deere Garden
I have a cub cadet model 1420 with hydrostatic drive that will not go forward or reverse. The drive belt is moving and the hydrostatic unit was replaced 3 years ago. I still have to engage the lever to...
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
Sep 28, 2010 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Mowing right along and suddenly the tractor won't go move
it's 1 of 5 likely things
The drive belt from the engine to the transaxle is totally slipping or broken
The linkage from the control pedal to the transaxle is faulty.
The transaxle is broken (not user fixable)
The by-pass rod is pulled out
The brake pedal is pushed or the linkage is stuck in the "brake" position.
Jul 11, 2010 | John Deere 22HP Hydrostatic 42" Riding...
John deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
May 26, 2009 | Garden
Toro TimeCutter SS4235 - 20HP 42 Zero Turn Mower Logo
42 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
