Question about Philips RWSS5510/00 Wireless Receiver for rear speakers
Where can I buy the Philips Wireless Rear Audio Transmitter?
I heard They do not make them anymore.
2 Suggested Answers
SOURCE: Philips LX3950W - no signal to rear speakers
check to se if your reciever channel number is set to the same as your transmitter channel number. press and hold down sound butten on remote to set transmitter number .set reciever number button on reciever unit. try setting both to number 4.
Posted on Feb 18, 2010
I have the philips mcm530 micro system and want to tune in a wireless speaker to the system so I can take the speaker outside. Is that possible?
The philips only receives bt audio it doesn't transmit them. You need a wireless system that includes a receiver and transmitter. The transmitter needs to be able to be connected to the speaker outputs of your philips system. Since I don't know what country you live in it is difficult to recommend anything as what is available in one area may not be available in another
Sep 01, 2016 | Philips Audio Players & Recorders
How can I hook up wireless headsets to direct tv box?
You must have wireless transmitter provision in your TV,to get connected to Headset.
Or you may buy suitable external wireless transmitter and connect it to your TV ,audio output and receive audio,in your head set.
May 03, 2014 | Sony Audio Players & Recorders
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
I am trying to hook up my Sentry wireless H0802 headphones to the TV. I have the transmitter plugged in and working, and the cables from the wireless transmitter plugged into the audio-out jacks in the...
There may be no audio output present at the rear of the TV. On some TVs, you have to turn off the internal speakers to direct audio output he rear connectors.
Feb 22, 2018 | Sentry HO802 Wireless Headphones
How can i make a simple wireless speaker ?
There isn't anything too simple about wireless communications. First you need a transmitter. Your headphone output would be a likely source for your transmitter. Once you have that in place you will need a receiver of the same operating frequency as your transmitter. The receiver will demodulate the signal and you will be left with a low voltage audio signal which would then need to be amplified. Amplifier power gain would be dependent upon a few things. Size of speaker, output power desired etc etc. All in all it would be cheaper to buy one. Good Luck!
Feb 08, 2010 | Arcam AVR-200 Receiver
Dec 29, 2009 | Philips LX3950W System
USB Wireless transmitter
the wireless transmitter use the same frequency as your wireless network and there should b a conflict. there is a way to change the frequency on the usb transmitter. once you do that, you should be ok.
Jan 02, 2008 | JVC RX-D301S Receiver
THE TRANSMITTER IS BROKEN
Dear sirm bu y the camera , it will be available for 12~15 USD in ur area i think .
Nov 13, 2007 | Sabrent Sbt-Scnv / Color / Mini Wireless...
Wireless headphones
If you're handy, you could rig up a wireless solution to this. The problem is that you have two screens, each presumably playing a different movie. If you purchased an off-the-shelf wireless transmitter accessory, you could connect it to one of the screens. But then if you purchased a second wireless transmitter accessory, and connected it to another screen, you would need to make sure both wireless transmitters were operating on different frequencies, so that each person could wear a different pair of headphones and listen to their own movie. Hopefully this makes sense. You could use either an FM Modulator to do this, or an Infrared Audio (IR) transmitter... Remember, these units aren't like factory installed headrest systems; they don't have the wireless audio transmitter already built-in, so you can't just buy wireless headphones and listen to them.
Aug 17, 2007 | Venturer PVS62911 Car Video Player
Philips RWSS5510/00 Wireless Receiver for rear speakers Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
