Question about Vehicle Parts & Accessories
Avital remote start works to star engine, without the remote start it will not start.
  • 10 Answers
You probably have a bad ignition switch that's why the remote start will work it replicates what the ignition switch does,or you have a coded key and had a new key made and not programed the remote start module has this code stored so it can send the car the code when remote started. What year make and model is the car?
Posted on Feb 05, 2015
4 Suggested Answers
ltfrc
  • 227 Answers
SOURCE: engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
Posted on Jan 28, 2009
ltfrc
  • 227 Answers
SOURCE: cranks but engine doesn't start avital remote start
I beleive it is a pink wire for the ignition. If you can locate where it is connected this is your ignition wire. It may have worked loose under the dash.
SOURCE: my avital 4113 car remote
DEI sent out a recall on a batch of theit antennas for this sysetm that were remote starting the car by its self. If you call customer service they will send you a replacement antenna and this sould fix your problem.
Posted on Jan 26, 2011
Disable timer on avital remote control
i think the engine rev needs to be turn down a little
Jul 14, 2014 | Hardware & Accessories
Avital remote start troubleshoot
Reset your PCM codes. Reset security codes -
www.ehow.com/how_6615404_program-used-keyless-entry-remote.html
Mar 07, 2014 | Vehicle Parts & Accessories
Avital 5303 kills engine while driving 1998 honda civic
you check to see if the engine was hot or something like if the water level in the radiator was down the sensors in the security system would pick it up
Jan 27, 2014 | 5303L 2Way LCD Remote Start Security...
Avital 4003 with xpresskit xk09 install in a 2006 chevy silverado 2500HD gas engine. how to wire all the wires to get it working with the factory key fob.
disconnect battery remove the engine mount bolts jack up support from top remove starter and flywheel inspection cover remove mounting bolts for engine pan lower and remove oil pump suction pipe should come out then. don't forget to drain engine oil first.
Sep 12, 2013 | 4003L Avital 4003 Remote Start Module...
No lights with avital
If your vehicle parking lights are working at the switch then, the inline parking light fuse(15 amp) of the Avital unit may be blown.
Sep 22, 2012 | 4103LX Remote Start System with Two...
Avital 4113 makes my cars horn constantly go off
The most likely causes would be an improper installation or a failure in the receiver unit. I'd be inclined to take it elsewhere to check the installation. Hopefully you still have the instructions & paperwork that came with it.
Good luck.
Feb 10, 2012 | 4113LX 1Button Remote Start System with...
We had the Avital 4003 keyless engine starter remote installed on our 4Runner in July when we purchased it. We shipped the car overseas and now that it has arrived the renmote will only start the radio...
You mean the igniton powers up but it does not start, correct? Sounds like the remote starter is not sending power to the starter. Did it ever work? It's possible that one of the 30amp fuses (one that supplies power to the starter output of the remote starter) is blown. If there is 12 volts present, check for voltage at the starter wire (purple) from the remote starter. If it has voltage,make sure it's connected. Also make sure that the harnesses of the remote starter are completely plugged into the module.
Sep 26, 2010 | 4003L Avital 4003 Remote Start Module...
I got avital remote control starter and the car cant star
What kind of vehicle? And did you wire it into the alarm? If you reply with a vehicle year and model I can give you the wiring diagram.
Jan 13, 2010 | Car Audio & Video
Cranks but engine doesn't start avital remote start
Jan 28, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Engine cranks will start fine with key remote will not start it
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
