Question about Camping, Backpacking & Hiking
What battery is in the mission cop spotlight 2000000 spotlight and how can it be changed
This torch will not charge
2 Suggested Answers
CarlGlas
  • 283 Answers
SOURCE: Where can I get a replacement charger for my
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. www.blackanddecker.com/CustomerCenter/Default.aspx
Posted on Jul 29, 2010
I NEED A POWER CORD CHARGER FOR THE 3,000,000 CANDLE POWER HALOGEN SPOTLIGHT. WHERE CAN I FIND ONE
If this is the usual sort of halogen spotlight, it is usually supplied with a mains charger adaptor and a lead to charge it from the car cigar lighter socket.
Both those items are also commonly supplied with a range of car-related rechargeable items, torches, jumpstarters and so forth.
I have several such items and I find the 12 volt lead and mains charging adaptor completely interchangeable between all of them. Rechargeable halogen spotlights generally have a very disappointing battery life of around 20 minutes unless a very expensive professional model is bought.
If it is not a rechargeable type that must be permanently connected to the car cigar lighter, the power cord is usually permanently fixed to the lamp but if it isn't, the cable will need to be substantial enough to carry several amps - something similar to that of perhaps a large coolbox.
Apr 11, 2017 | Camping, Backpacking & Hiking
How do I get my Stanley 2m series spotlight to Charge?
To take the charge the inbuilt battery must be functional. Once the battery goes bad you will be unable to charge the unit or it will take a small charge and die rapidly thereafter.
You may or may not be able to change the battery. It depends on the manufacturer of the product so you should consult the instructions that came with the item if you still have them.
Nov 28, 2015 | Stanley Camping, Backpacking & Hiking
How do I buy a changer for a mission cop 2,000,000, candle power spotlight
http://www.fixya.com/support/t11259058-charger_mission_cop_spotlight_2000000
Feb 19, 2015 | Mission Camping, Backpacking & Hiking
How do I change the bulb in a 2m series spotlight?
replace bulb with 12 volt, H3 100 watt only
See the pdf of the manual I uploaded.
Sep 16, 2014 | Stanley Sl2m09 Rechargeable Spotlight...
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
Where can I get a replacement charger for my Vector VEC138BW 2000000 cp spotlight
Jul 06, 2010 | Vector 2M Pwr Rch Spotlight
Cyclops spotlight wont charge
It is indicating that your battery needs to be replaced, it will not hold a charge.
Oct 23, 2009 | Camping, Backpacking & Hiking
Dead battery
It depends on what voltage the internal battery is. If it's a 6 volt, the charging voltage will be a little higher, close to 6.5 to 7 volts. Most of these spotlights are 6 volt. New batteries can be found at Battery International: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Mar 13, 2009 | Vector 3 Million Candlepower Rechargeable...
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Camping, Backpacking & Hiking Logo
81 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
