Question about HP Compaq dc7100 PC Desktop
Red light beeping
Iif a red light that beeping when I turn my computer on
leecom72
  • 4806 Answers
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
Posted on Dec 14, 2008
martmet
  • 52 Answers
SOURCE: 5 Beeps with red light.
Well those beeps tells you that something is going wrong with the hardware. Could be the memory/processor or something going bad on the motherboard. Well you could try a few things (new memory/harddrive/removing all PCI cards except the video card) to try to isolate the problem. But you probably end up at the computer store where technicians can take a look at it. So I would go there first since it's probaly gonna take some time to figure it out anyway. Also try to remove anything you installed recently. Good luck!
Posted on Jun 08, 2009
miskaone
  • 21 Answers
SOURCE: short beep and red light
Did your Bios Battery Die?
5 short beeps = BIOS recovery successful
Usually means bios has lost settings some how. You have have more significant issues if there was a power surge.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07107
Posted on Jan 02, 2010
SOURCE: When attempting to turn the
If the computer beeps 5 times and flashes a red light it could be a memory failure. You should make sure that the memory is seated right in their slots. Open up the computer and you should see two vertical sticks towards the top of the computer, make sure that they are fully inserted into their slots. If that doesn't work try to find a stick that you can replace them with to see if the memory it self is bad.
Posted on Mar 01, 2011
  • 133 Answers
SOURCE: WHEN I TURN MY DESKTOP
sound to like something isnt connected properly or something has failed like ram cpu ect..
Posted on Mar 24, 2011
Turn the computer on, steady red light and beeping.
Have check for the pins connections who makes it to be master or slave? Have check how you plugged yours cables at HDD? Know that , the cables are plugged as following:
After to put in the power cable, the data cable must be put in in the way that the Red line must be in the direction of power cable. Check all this , if your HDD was good before , i believe that it will work.
Thanks , good luck!!
Sep 19, 2009 | Dell PowerEdge 1800 Server
Turn power on press swich at front red goes to green ie on 2 seconds turns off red
Its called the red light of death, turn it back off then hold down the button, it should beep once then beep twice quickly. It takes a few tries
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Hardlocked;beeping and red light on motherboard;will not restart
Something on the motherboard has failed, and the RED light confirms it.
Turn your computer off.
Remove ALL of the RAM. Turn your computer on.
Do all the fan(s) start to spin?
Do you get the _same_ "beeps" as before, or some different pattern of beeps?
If it has more than one stick of RAM (and the RAM is _NOT_ labelled 'DDR2'),
then remove all but one stick of RAM, turn your computer on, and try to reboot.
Same beeps?
Turn your computer off, try a different single (or pair of) sticks of RAM.
Caution: before doing any of the above, your computer could be within the "WARRANTY" period,
i.e., it could be fixed/replaced for free!
May 26, 2009 | Abit GD8 Motherboard
Ps3 problem
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
May 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3
insetad of restoring the filing system, restore the default settings ore restart the system
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
Ps3 says cannot start the correct hard disk was not found
try safemode
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Acer aspire T120c wont start red light blinks once when i push the power button
If you turn on the computer and it will beep once and the red light blinks means the computer is starting will.. but if the computer beep once and the red light blinks once means there are something missing or something bothering the computer.. try this Check the connection cable of your computer, the power source, the hardware interface, and if you installed a new hardware, try taking that hardware out and turn on again the computer. if the problem still exist try to disassemble and assemble the hardware of the computer. You must have someone with you know how to assemble and disassemble the computer hardware for safety method TY.
HOPE I CAN HELP
Dec 05, 2008 | Computers & Internet
Red dot and beep
The problem is in most cases the Power Supply given is of too low of Wattage, at 1.5. After some time, it will no longer provide the drive the needed power, thus the red light.
Try another similar power supply of higher Watts (my Maxtor has it at 2.0 watts.
Try getting Higher power Supply from Radio Shack. Store Tech will Help you.
Lastly, inside the enclosure is simply a typical Hard Drive. Remove it and Slave it to your PC.
Jul 06, 2008 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Beeping Upon Bootup
dependent on how many beeps you hear is dependent on what might be the problem. A fuller explanation from pushing the power button to nothing happening would be more than helpful. Beeps in a Poweredge can mean motherboard, memory or as you said power supply problems.
May 06, 2008 | Dell POWEREDGE 2400 Server
HP Compaq dc7100 PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
