Question about AOC Computers & Internet
How to fix aoc monitor display input is not support
SOURCE: Input not supported
1. Restart the computer.
2. When the computer begins to reboot, press the F8 key repeatedly in one second intervals until the "Windows Advanced Options" appears.
3. Select "Enable VGA Mode" and press ENTER.
4. Select your operating system from the list and press ENTER
5. Follow your normal log on procedure.
6. RIGHT CLICK with mouse anywhere on your desktop.
7. Select PROPERTIES.
8. Select SETTINGS then select ADVANCED.
9. Select ADAPTER then select LIST ALL MODES.
10. Refer to your monitor user's manual or Quick Start Guide for the recommended resolution or mode for your monitor.
11. Select OK then APPLY then OK.
12. Depending on your computer setting, you may need to re-start the computer for the changes above to take effect.
Hope its useful!
Posted on Aug 20, 2008
  • 25 Answers
SOURCE: problem in my aoc monitor
pls replace control button 4no
Posted on Dec 12, 2008
SOURCE: AOC 53N PROBLEM
DO YOU KNOW HOW TO SOLDER. IF SO, TRY TO OPEN THE MONITR AND LOCATE THE VERTICAL SECTION AND YOU WILL FIND LOOSE SOLDERS. A SINGLE HORIZONTAL LINE MEANS THAT THERE IS A PROBLEM WITH THE VERTICAL LINEARITY OF YOUR MONITOR. FIND SOMEONE WHO KNOWS HOW TO FIX COLD SOLDERS
Posted on Dec 19, 2008
techie2050
  • 126 Answers
SOURCE: aoc monitor set up
re install the drivers for garphic card or video card of your computer
thankyou for using fixya and dont forget to rate the solution
have a nice day
Posted on Feb 19, 2009
budmrtn
  • 11361 Answers
SOURCE: My AOC monitor went black and has this error
The video resolution of your PC is too high for the monitor to display.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 01, 2010
Power led brightly on but no display on AOC S5G10
It is understood that your AOC monitor is not working, you had followed troubleshooting steps like connecting VGA and Power cable from monitor to computer and the monitor panel light is ON but still no display. You have tried connecting another monitor and it is working fine, so it is advised to contact AOC support to check if the monitor is under warranty and it can be replaced or repair. To help you do these, please follow the link given below:
http://us.aoc.com/aoc-technical-support/?page=contact-technical-support
GuruAid.com
May 24, 2016 | AOC Computers & Internet
Aoc monitor shows error message while connecting with i ball tv tuner
What resolution is the AOC monitor capable of using?
What is default resolution of the device you are connecting?
If the default is 1080P and the monitor is not 1080P capable then that would be your problem. You could attach to another monitor or HDTV and possibly turn down the resolution then try again.
Feb 05, 2016 | AOC 917Sw 19" LCD Monitor
I connected my AOC moniter to TV tuner card.I can watch all the TV channels now but a box in the middle of screen displayed as input not supported. Please suggest me???
not certain what that means but check the broadcast protocols that are options of the card's menus and the protocols the monitor can use.
Also check the maximum resolution of the monitor, the refresh rates it can support, the modes too and check that the settings on the cards software are not exceeding them, it may be that the resolution or refresh rates are beyond the monitor's capability to display
Jul 02, 2015 | AOC Televison & Video
AOC monitor says OSD locked
OSD means on-screen display. As you make adjustments, they are displayed on the screen. You may have to press the OSD button to unlock it.
Sep 06, 2012 | AOC V22 22" Monitor
Remove banner "input not support" in 19" wide LCD 917Vw monitor. i am working different operating systems development some i try to excute some work this banner will appear pls help me..
You PC video setting is too high for the monitor to support, you need to set the PC resolution to 1440 x 900 @60Hz, try that first. Here is the spec for your monitor: http://reviews.cnet.com/lcd-monitors/aoc-917sw-lcd-display/4507-3174_7-33109821.html?tag=mncolBtm;rnav
Unless there are problemswith the logic board in the monitor if the resolution is already set correctly.
Mar 17, 2010 | AOC 917Sw 19" LCD Monitor
AOC LCD MONITOR
The cable from the Monitor USB input to PC USB output is good? Check to see if you do have 5vdc on pin 1 of the USB connector. Your monitor is basically a powered USB hub when it is connected to PC through a USB cable.
Jan 20, 2010 | AOC 22" Widescreen LCD Monitor
Bought new aoc monitor and plugged in and all I get a floating screen safer saying "input not support".
Your display resolution is set to something outside the range your AOC supports.
Start Windows in VGA mode (pick that option from the startup menu you get when you press F8 after the manufacturer's logo comes when you turn the computer on). Then set the display mode to 16-bit color and 800X600 resolution. This will allow Windows to start up next time with settings just about every monitor can handle.
Once WIndows is up and running, make sure you change your display settings to something the monitor can handle. Specs are in the manual or on the manufacturer's website, but resolution of 1024X768 should be another safe choice. You should also think about installing any driver software supplied with the monitor.
Dec 08, 2008 | Computers & Internet
AOC 53N PROBLEM
Aug 06, 2008 | AOC 5 En 15" CRT Monitor
Computers & Internet Logo
12 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
