Question about Refrigerators
Bosche refrigerator KE62E218 freezing up & alarming both fans running heater ok not short of gas has anyone got the sensor ohm reading
  • 4 Answers
Your drain hose may be cocked you can unplug the refrigerator for a few hours if you can locate the drain hose try pouring some warm water in then clean the fridge and this should help...
Posted on Apr 23, 2014
  • 958 Answers
SOURCE: Defrost Heater Resistance Range
21.3 ohms is just fine for a defrost heater. this heater is low wattage since it is an adaptive defrost. you could have problem with temperature sensor since you have replaced the board already.
tnx for using fixya,
drcool
Posted on Sep 30, 2008
  • 18 Answers
SOURCE: whirlpool Model # GB2SHTXTS00 refrigerator not cooling.
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
Posted on May 29, 2009
SOURCE: measurement of defrost heater elemnt resistance in E 442B
yes, should be 165
Posted on Aug 06, 2009
  • 108 Answers
SOURCE: The freezer side does not freeze on the top shelf.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Posted on Dec 04, 2009
Sea Breeze
  • 4654 Answers
SOURCE: My feezer is not defrosting properly, I ohmed def heater
I noticed that you left the most likely part out. Defrost Timer=> 215846602 Click Here=> FRT17B3AW5 User Manual on page 17 letter E Click Here=> FRT17B3AW5 Wiring Diagram some models had Adaptive Defrost there but I think yours has the defrost timer. If this was helpful please rate me. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Mar 21, 2010
Noisy when compressor starts
MAY BE LOW ON FREON OR;
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Mar 28, 2015 | Engel 43 Qt.Portable Freezer.
Started to be noisy when compressor starts up. Tried cleaning dusting motor area including fan. Seemed quieter but becoming noisy again
Mar 28, 2015 | Refrigerators
Bosche KE62E218 Freezing up then alarming both Fans running not short of gas do u Have u Got sensor ohm testing numbers thanks
A bit more information is needed, what is freezing up? Where is it freezing at. You can contact Bosche at: http://www.bosch-home.com/us/ they would be happy to help you.
Apr 23, 2014 | Kitchen Ranges
Not freezing wont get down to temparature, stuff has defrosted, makes whooshing noise when dooor opended and light flashes. Its googsed Whirlpool ARC4030UK
Hi.
If there is whooshing noise, check first the damper fan. See if the fan is broken or if fan duct is obstructed. Check the fan in the evaporator system (defrost system) behind the fridge's firewall.
The problem is commonly the defrost system. Fan or thermostat do not work. As result the coils freeze up. With coils frozen the condenser will go under stress and will loose efficiency. The effect is the system not producing enough cold.
The defrost system comprises defrost thermostat, heater, defrost control and fan. The parts that fail more commonly are thermostat and heater. Both parts are located behind freezer firewall and tested reading impedance with a multimeter. Element and thermostat are faulty if they return Ohms infinity (the circuit is open) when reading impedance with a multimeter at the part's contact.
If thermostat and element are OK, the next part to be tested is the fan. Fan can be tested by simply checking that the motor is running when energized.
Here a tip explaining how to deal with defrost problems on a different fridge model: Fridge not cooling. Procedure is similar with your model.
If defrost system is not the culprit, check if the compressor is starting and working properly. If compressor is not starting properly replace the relay and capacitor kit connected to the compressor motor. Compressor motor has long warranty. If the motor itself is defective call the manufacturer to check warranty terms.
If compressor motor and starter kit are OK, defrost system is OK (including defrost control) it can be a refrigerant leak resulting in low gas pressure in lines. In that case the compressor motor will stay on most of the time.
The most common faults resulting in no heat are due to defrost system problems or to defective compressor motor starter kit.
You can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Aug 28, 2011 | Refrigerators
My freezer is working but the refrigerator is not cooling.
Hi.
The problem is common. The coils freeze up because of a defective defrost system. With coils frozen the condenser will go under stress and will loose efficiency. The result is the system not producing enough cold to refrigerate the fresh food section while the freezer section instead keeps working.
Here a tip explaining how to deal with a similar problem on a different fridge model: Fridge not cooling. Procedure is similar with your model.
Regards.
Ginko
Aug 20, 2011 | Refrigerators
Alarm won't stop beeping
Door left open or temp is too warm. most I found is heavy ice build up on freezer evaporator, very easy to tell, pull out one of the drawer and look on the back wall, it should not have any ice on it (a little frost is OK). It may be bad Evaporator sensor, Evaporator fan motor is not running, door evaporator fan reed switch installed upside down,bad connection on defrost heater connector, bad defrost heater element, open heater HI limit switch, open gap on door gasket and compressor never stop running. If no ice build up and compressor is running but temp is rising then it may be sealed system problem. Good Luck.
Mar 01, 2010 | Liebherr Refrigerators
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
Heater turns on runs for short time display reads 120 or so but temp stays at 80 or so
It is probably your thermistor. It is screwed into the header (the place where the pipes come out). To know for sure you would have ohm it out (I am not sure of the ohms of this particular model). If it ohms out ok then it could be the control board.
Apr 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
I have a GSS20IEMAWW that the coils freeze up
Check the defrost heater located on the bottom of the coils. Short have a pretty solid short if using and ohm meter.
May 23, 2007 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
