Question about Troy-Bilt 25cc 4-Cycle Heavy Duty Gas Blower TB4HB EC
Leaf blower runs but does not blow
Impeller appears to be off-center
2 Suggested Answers
randyprevost
  • 887 Answers
SOURCE: fix impeller on try bolt leaf blower
...and then what?
Posted on Dec 01, 2012
I'm not asking about a leaf blower It's a toro snowthrower model # 38600. what's the proper way to remove and replace the impeller blades?
You have to disassemble the entire front of the snow blower. This means removing the snow shroud, auger bits and then getting to the impeller blades. I did it once and it took me about 1 1/2 hrs to complete.
Dec 14, 2014 | Toro Garden
After replacing the flywheel on my leaf blower, the impeller assembly keeps spinning off while I'm trying to start it. Why won't it stay after tightening it down?
try disassembling the unit again and when reassembling add some loctite to the shaft when you put the nuts back on. Let it set overnight to dry and then try running it again.
Nov 08, 2014 | Garden
How to repair Toro Super Blower no longer blowing, only vacs/intakes?
when you remove the vac part there should be another "grid type" part that snaps in place of the vac tube. This engages the safety switch and keeps your fingers out of the impeller.
Oct 05, 2014 | Toro 51592 Super Blower Vac 3-In-1...
Hitachi RB24EAP engine start but no blow
Check the impeller (on the side opposite the pull starter) to see if it is locked to the drive shaft (in the center of the impeller). The shaft could be spinning but, if the impeller is loose on the shaft, it can't spin fast enough to force as much air through the nozzle as it should.
Oct 29, 2012 | Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH...
String stuck in fan
Remove the string.... split the plastic shroud in half by removing all the screws ( allen ) once the impeller is uncovered remove the center nut with a 3/8 drive air ratchet and remove the impeller then you will be free to remove the string. While you have the impeller off double check the four motor mount screws and make sure they are tight. reassemble.
Nov 22, 2009 | Poulan Garden
Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 13, 2009 | Toro Blowers Rake and Vac - Electric...
Vac Attack II leaf blower knocks like HELL.
Is your fuel mixture ratio 40:1? Plus there is not adjustment to the timing. It could be a loose flywheel or a rod bearing going, or a loose impeller. Basically something at the factory did not do there job. It has a 1 year warranty on it. Or you can take to a shop and for a diagnostic fee, have an estimate done to see what it would cost to fix.
HTH
Good Day.
Oct 30, 2009 | Garden
Can't figure out how to attach the vacuumm to the blower of our Craftsman Gas Blower/Vac #7179474
I know people buy this equipment to blow and vacuum. The main problem is if you vacuum up something that hits the impeller and breaks off one of the fins; you will have to take it somewhere to get the impeller replaced.
I would stick with it using it as a blower and get the rake out to get around the bushes.
Good Day.
Oct 25, 2009 | Craftsman 4 Cycle Blower/Vac
My home lite yard broom blower has a vibration at hi rpm
I'm not sure if I have an answer, but I had one that had a broken impeller on the pick-up fan. You can check this by removing the shroud in front of the pick-up fan on the bottom of the blower and check that all of the impeller's are the same size.
Jun 22, 2009 | Homelite 'Yard Broom' Leaf Blower
Troy-Bilt 25cc 4-Cycle Heavy Duty Gas Blower TB4HB EC Logo
52 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
