Question about Dyson DC25 Vacuum
Parts manual Plastic piece wishbone style with spring came off
I have an older Revlon round styling hairbrush and the small metal ring where the handle attaches to the brush and the round plastic piece need to be replaced.
parts for small appliances are seldom available as the cost exceeds the price of the unit
you may have to consider using it without the ring or junk it
Dec 01, 2015 | Vacuums
How to get in to a dual v-124A.
They are not made to be repaired. You may have to JB weld some parts in there,after you snap off the plastic.
The replacement brushes are on Ebay,after you measure the size and style.
Nov 11, 2014 | Vacuums
The clean water tank is leaking terribly
This was a common problem for the models that were manufactured with a two piece tank. These tanks will have a colored soap container attached to a clear water tank. The plastic was too thin around the valves and would crack. You need a new style one piece tank ( # 42272104 ).
Mar 15, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I shipped my brother PE 770 embroidery machine purchased sept of 2010, to a lady who perchased it on ebay. Had used only once. Everything worked fine.I shipped in the original formed styrofoam box. I...
This is a link to the manual for this machine. Do you see a picture in the manual of the parts you are describing? Reply with a part number and I will do my best to help.
Here is the manual link
Thank you
Feb 26, 2011 | Vacuums
I n eed small plastic white piece that has wire
Could you be looking for a notebook coil spring holder? As an alternative?
Sep 14, 2009 | Sharper Image SI570 Steam Wizard Handheld...
When I took the base cover off the vacuum to clean the roller, a metal piece that is bent in half, as well as a white plastic stick piece came flying out. I think it might have to do with holding the...
They go in the slot beside the right wheel. Metal spring first, (the open ends facing away from front of vacuum base. The white nylon piece lays parallel and directly on top of the metal spring, round edge up, and aligned with the open ends of the metal springs.
Aug 09, 2009 | Eureka 411A Upright Vacuum
I sucked up a piece of plastic. Removed plastic.
This style machine picks up the dirt/debris with the roller, sends it through a fan and into the bag/cup. This is a very common problem since a plastic fan turning at 2000 rpm meeting anything hard is going to cause damage. (Loose Change, toys, anything small) This fan creates your suction and when it is damaged it creates none, it also is the "noisy" part of any vacuum and becomes extremely noisy when damaged.
To Replace this part:
  1. Remove hood (4 screws underneath)
  2. Remove handle assembly ( one bolt through handle and slide off)
  3. remove the belt
  4. Remove the 2 brackets on each side of the motor that hold it in place. (4 screws)
  5. Lift motor off base assy.
  6. Remove rubber cuff around top of motor assy.
  7. Remove the 6 screws on large size of motor assy. and remove cap.
  8. Turn fan (or whats left of it) off of spindle by holding belt drive spindle on oppisite side of the motor.
  9. Replace fan and reassemble.
You can also take this to most any Hoover authorized service center, they would have the parts in stock and could probably do it for less than 50 dollars. Check their dealer locator for a local center.
Best of Luck!
Jun 09, 2009 | Hoover U5290-900 Upright Vacuum
Electrolux 2100 foot switch
The owners manual is HERE: http://www.aerusonline.com/service/manuals.cfm
But it does not show the inside of the foot/power switch
Mar 03, 2009 | Vacuums
Pump Assembly Drive mechanism seperarted into two pieces
I believe the pump assembly can be replaced it is a15 dollar part.that is what works the brushes. Ijust took mine apart and looked at it the end snapped off.
Dec 10, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Broken Belt Trouble and also plastic piece with spring has a broken part
you can order new parts through Bissell.com web site they are very hepful
Oct 28, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Dyson DC25 Vacuum Logo
46 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
