Question about Ubi Soft IL-2 1946 PC
Throttle stick not working properly.
Everything works except for the throttle stick on the joystick. joystick throttle imputs only change power settings from 55% and 0%. it is a saitek cyborg-x joystick. I'm playing IL-2 1946.
    Brigadier General:
  • 4,090 Answers
Take it back to seller heap of cr*p
Posted on Jun 20, 2009
How do I make the throttle work?
Have you checked the devices panel and checked that the stick is being recognised?
Press
Start>run>
and type joy.cpl
return
To view the joystick control panel.
If the throttle is showing and you can test it, it will be available to games that support it.
Oct 12, 2014 | Microsoft SideWinder 3D Pro Joystick 63545
My throttle does not respont properly. i can not
Hello
Unplug joystick from pc.Power off pc.
Restart pc.
After pc starts plug joystick back in.Should reinstall itself.
Once done recalibrate.
Sep 19, 2011 | Logitech Extreme 3D Pro Joystick
Doesnt work when i push or pull on the stick
If it's anything like an authentic joystick control, there may be a switch where your fingers rest which must be gripped/engaged in order to achieve movement, but i've never actually seen this controller so I can't be certain.
Oct 04, 2009 | Guillemot ThrustMaster Top Gun AfterBurner...
Joy stick not working
the problem is because the wires are disconnected form the stic
May 29, 2009 | Sony Ericsson K300i Cellular Phone
Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
Nov 23, 2008 | Saitek (PS28) Joystick, Throttle
Joy stick is not working
Good day
SE K700i is noted for its sensitive joy stick. due to its normal wear and tear, the time will come where the joystick will no longer function properly. i suggest that you have it checked by a reliable technician. they may check for dust and dirt that have accumulated through use or they may suggest for replacement of the joystick.
Sep 26, 2008 | Sony Ericsson K700i Cellular Phone
Microsoft sidewinder force feedback 2 joystick
Well, I just noticed this exactly same problem with my new PC, so i try it with my older PC and it works fine, I´m not sure if this has something to do with the USB 2.0 or the driver, but i was not able to find the version 5.X for it, microsoft page only has the version 3.2.
the extrage part is that both PCs are using the same version of WXP.
Feb 22, 2008 | Microsoft SideWinder Force Feedback Pro...
Microsoft Force Feedback 2 joystick
I have the same problem - have lost all stick forces (everything else works fine) and the Forces self test that can be run from the original CD software says there is no electrical power. Have changed the fuse etc. but problem remains. I think something inside the device hardware is bust. Like you I cannot find anything on the Internet as to how or where the device can be repaired!
Simon Kuczera
Dec 22, 2007 | Microsoft SideWinder Force Feedback 2...
Suncom Technologies F-15E Talon
i will buy both stick and throttle off of you..."if" the price is right. ;-)
Beowolff29(at symbol here to throw off spam bots)hotmail.com
anyway...this is old technology stuff...as it is non-USB and windows xp and other new windows don't like Suncom stuff too much. but it can be done. attach the Talon stick to the throttle via it's two plug in ends. you'll see how they plug into the back of the throttle. once that's done, attach a NON-USB keyboard (to make the stick and throttle programmable) into the back of the throttle via the backside of one of the plugs from the stick that you plugged in earlier.
go to Radio Shack or elsewhere and buy a Belkin or whatever "joystick port to USB converter" unit. the salesman should know exactly what it is. cheap...maybe 8 to 10 bucks. also while you are there, buy a big keyboard end to little keyboard end (not USB) end converter adaptor. maybe four of five bucks for this. it converts the really old (BIG) keyboard ends to the more 'normal' (SMALLER) keyboard ends that are usually on the back of your computer. okay, almost done.
plug the USB converter into the big joystick port plug that is attached to the split line that is coming out of the back of your throttle, it's only go on one way so should be easy to do. attach the 'now' USB converted plug end into a USB port on your computer. the "OTHER" end of the split 'throttle' cable end will have that BIG keyboard end on it...plug the BIG to LITTLE adaptor that you bought into that...and simply plug it into the back of your computer where a standard keyboard plugs in.
viola! you are done with that. you may have to monkey around with the switch on the USB adaptor to get the thing working right. it has several settings on the slider switch for different things. try one till you get the one that works best.
go into window's control panel and pull up your GAME CONTROLLERS program. it should now show USB ADAPTOR CONNECTED in the joystick window. configure as per usual and test. there may be some jerky stuff while configuring but keep trying till you get it like you want it. that's it. go in game and TRY it out. some adjustments (trial an error) may be needed, but it should now show up in game and with the keyboard attached, all buttons on both throttle and stick should now be programmable and useable.
not perfect, but it will work fairly well. remember, this is old technology and it is hard to get and keep it tuned into the newer working systems. you may occasionally lose your stick, and have to RE-CONFIGURE all over again. a small price to pay for a WONDERFUL, REALISTIC fighter stick! u can email me if you get into a jam.
Oct 22, 2007 | Suncom Technologies F-15E Talon...
Ubi Soft IL-2 1946 PC Logo
1,573 people viewed this question
Top Ubi Soft Video Game Consoles & Games Experts
dante
Tom Chichester
MegaByteMe
MegaByteMe
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
