Question about Shop Vac Shop-Vac& Mini Hang Up Wet/Dry Vac Vacuum
Shop vac stopped working
For no obvious reason, my shop-vac model 2015A stopped running after being turned on moments earlier. any ideas as to why? is there a fuse that could have burnt out?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 55 Answers
Motors have a thermal safety fuse in the field winding. If it overheats, it will blow and either can be replaced or the whole field winding will have to be replaced. It is wired and is not considered to be a user servicable item.
Posted on Oct 05, 2014
5 Suggested Answers
  • 120 Answers
SOURCE: burned out motor on QPL625 Shop Vac
well if you can find the motor ( find a place that deals with the manufacturer directly so you get the right part ) and it isnt to expensive, most shop vacs are pretty easy, if you look under the top you should see about four screws, remove those and the top should come of giving you access to the motor, take note about the wires and what they hook up to. i doubt the motor is fastend down other than that.
Posted on Sep 18, 2008
SOURCE: craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Posted on Jun 09, 2009
  • 7 Answers
SOURCE: shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Posted on Sep 28, 2009
SOURCE: Have a Sears shop vac, mod 113.172. The motor doesn't take in
THE HOLE THAT CATCHES THE SUCTION BALL CAN BECOME BLOCKED LETTING DUST GO THRU THE MOTOR.
Posted on May 01, 2011
Agitator bar on UH4700RM wind tunnel doesn't turn
Unfortunately you machine is a re manufactured vacuum and has a 6 month warranty. (The RM suffix indicates this ) You should take it to your local vac shop and let them look at it. It's probably a minor issue.
Aug 08, 2017 | Hoover U6630-900 WindTunnel Bagless...
I have a Craftsman brand shop vac [model # 113.77420]. It is still picking items when I sweep with it, but it has developed a very high pitched squealing sound whenever I turn it on. The sound makes it...
I have the same problem with a CTC Shop Vac. It's he bearings ... they're worn out and dry ... no lubrication. I've trid taking the motor apart and lubricating the bearings, then it runs super for a few uses but then the squealing starts again. Oitch it and buy a new one.
Aug 23, 2010 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Shop-vac model 90L550A motor wont run
Yes replacing the link would work, but that would not fix the cause. You have either pulled the wiring to the point of pulling apart the connection or there is a short. Which would be in the way of a grounding effect causing the link to heat and melt. A safty issue to be sure. Check all contact with housing and motor to make sure there is not an underlying problem to start with. Unpluged of course
Feb 22, 2010 | Vacuums
Switches will not turn off unit. model #cv450w
If the switches on the hose will not turn off the vac you have a short in the wiring of the vac pipe system or a defective relay on the circuit board. Plug the vac in again without the hose and disconnect the thin low voltage wiring were it plugs into or screws onto the vac.
If the vac continues to run once disconnected from the low voltage circuit you have a defective relay in the vac itself. Some are circuit board mounted , others freestanding. To avoid a service call you can take the tank off the wall and take it to a pro shop or remove the top hosing if you are confident and check out the relay for a replacement part.
If the vac stops your issue is in the house. Has any painting been done or any inlets removed lately.. check that area first for a short at the inlet. Go back to any and all inlets and remove them one at a time checking the mounting screws and backing plates for loose wiring which is touching either the metal inner wall plate in the wall or a common screw . Test the vac as you go.
If this does not help, you will need to examine the wiring in the house , running along the pipe. Again if anything has been disturbed recently, near the vac, or near any piping that would be your first suspect area.
Post back to advise.
Oct 18, 2009 | Broan-NuTone CV350 Central Vacuum
Craftsman shop vac no power when turn on
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
MY SHOP VAC STOPPED WORKING AFTER USING IT FOR A WHILE
If by stopped working you mean that it no longer has any suction, then check the hose for a clog and also clean all the filters.
If you mean that it literally stopped running, then the most common cause is a faulty switch. If the machine is still under warranty, contact Shop Vac for a replacement motor, Switches for shop vacs are not available, only replacement motors. If the machine is not under warranty you can either replace the motor or the whole machine.
Oct 22, 2008 | Shop Vac Vacuums
Shop vac 90L400 stopped working won't start
Oct 19, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Epic 6500 vac stopping for no reason
Could have a problem with the cord or the motor.
Apr 20, 2008 | Electrolux Epic 6500 Vacuum
Shopvac 2010
Just be sure to remove the paper filter bag that fits over the foam filter before vacuuming liquids. It's easy to get it wet and they don't work very well when that happens.
Dec 10, 2007 | Shop Vac 201-13 Wet/Dry Vacuum
Shop Vac Shop-Vac& Mini Hang Up Wet/Dry Vac Vacuum Logo
500 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
