Question about Poulan Garden
Poulan leaf blower loses power after warming up
Poulan leaf blower runs fine when cool when first started, but as it warms up it loses rpms and power.
  • 906 Answers
You need to adjust the carb set screw most likely out 1/4 of a turn.
Posted on Jan 25, 2015
3 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: poulan leaf blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • 430 Answers
SOURCE: got a craftsman leaf blower cranks up and runs fine for about 5 mins then starts losing rpms
ITs hard to diagnose these things over the internet, it could be so many things.
Is this a gradual loss of power? If so; Im sorry to say; that it sounds like its losing compression as it warms up. It is not cost effective to repair the unit.
If the loss of power is more sudden it could be a failing ignition module. Ive even seen spark plugs that quit working when they get hot.
To test this you will need a proper spark tester, laying the spark plug against the head will not provide an accurate assesment, and a can of carb cleaner. Run the unit with the air box cover and filter removed till it fails and immediately give a shot of carb cleaner in the carb and restart. If it starts right up it could be fuel related. IF it doesnt start right up then quickly test for spark. If no spark then its likely the ignition module. If it wont run on the extra fuel and it has spark then it has probably lost compression.
Posted on Nov 12, 2012
Poulan 2000 leaf blower shuts down after getting hot (7-10min)
Make sure your oil to fuel ratio is correct. You cannot run it on gasoline alone.
Oct 20, 2014 | Garden
My leaf blower starts cold but won't start warm
Test for spark when it is warm. You may have a damaged ignition module.
Oct 06, 2014 | Garden
What is the compression on a poulan leaf blower?
60 to 70 psi it will start fine. I fix Poulan blowers every day for a living
they are very easy to fix. A common problem is stuck piston ring.
Jul 10, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
Poulan gas blower runs but will not start when warm
back the carb screw out 1/4 of a turn.
Jan 19, 2014 | Poulan Garden
Got a craftsman leaf blower cranks up and runs fine for about 5 mins then starts losing rpms
Nov 05, 2012 | Craftsman 4 Cycle Blower/Vac
Homelite 2 yard broom 170
You have found the HI and LOW settings. The idle wouls be set by starting and warming the unit up. After warm up, take your screwdriver and turn the LOW screw OUT until the engine starts to lose RPM's. Turn the screw IN until it starts to lose RPM's. Once you have those two points, back the screw about halfway between. You can do the same for the HI setting if you need to. Good luck...Lee
Aug 23, 2009 | Homelite 'Yard Broom' Leaf Blower
I have apoulan 446t pro I can get it started with it full choke but it will die as soonn as I try to turn the choke off what should I do
how long will it run on choke? the newer equipment are jetted really lean to comply with EPA requirements. it should run once it warms up.....if not the air fuel mix needs to be richer.
Jul 05, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan PBV200 LE
Probably a low compression problem.
Oct 18, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
