Question about Vehicle Parts & Accessories
Photo showing location where to fill steering fluid audi a3 2005
    Sergeant:
  • 243 Answers
Again, my standard answer to these type of questions is to purchase a haynes manuel from either an auto parts store or i got mine off ebay, saved 10.00. These manuels have a wealth of knowlege, diagrams and instructions to help in such a task. Good Luck.
Posted on Nov 24, 2014
LOCATION OF TRANS FILL ON 1996 AUDI QUATTRO
the location is under the car at the transmission. this is lifetime fluid and audi intended that you never check or change the fluid !?!?
Jan 22, 2011 | 1997 Audi A4
Where does the power steering fluid go in a audi a4 1996 1.6 petrol and where does the brake fluid go cheers
the brake fluid reservoir is on the bulkhead at the bottom of the screen(i think cap colour yellow) and the power steering fluid goes into the cap marked pas(cap colour black)located at the side of the engine at the front of the engine bay.
Aug 05, 2010 | 2000 Audi A4
Where is the power stering fluid located?
The Audi power steering fluid reservoir is located on the drivers side inner fender well in the engine compartment right behind the head lamp.hope this helped thanks
Apr 25, 2010 | 2001 Audi A4
Power steering light has come on,on dash and steering not working,audi a3 fsi 2003 ,1st time it happened just turning ignition on and off solved the problem,now light stays on and power steering not...
Have you verified that the power steering fluid is at the right level? If it isn't, you need to fill it to the proper level using specific Audi power steering fluid (it's a mineral-oil-like fluid, NOT the stuff you buy at the parts store). If you've run the reservoir dry and kept driving, it's likely you've burned out the pump and will have to replace it.
Nov 12, 2009 | 2005 Audi A3
Hi, in order to top up power steering fluid, where can i locate it on a mazda friendee
In the engine compartment, towards the front look ofr components that are driven by the main belt. A picture of a power steering pump can be seen on this page in this link:
http://entertainment.webshots.com/photo/2265150650097469480sowGaS=productsHowTo&pageId=0900c15280213f88&subtitle=test
Notice the cap on the top where fluid is filled.
Aug 09, 2009 | 2001 Mazda MPV
Power steering
NO, DOT 4 fluid is brake fluid, not power steering fluid. The power steering fluid resevoir is black with a green cap.
Apr 20, 2009 | 2003 Audi TT
Audi power steering pump location
Before you replace the pump, check the filter located inside the oil tank. This filter cleans the oil before going to pump. REMEMBER that Audi uses a special oil!!! Not your normal power steering fluid! Mixing them could cause damage to the entire system!
Jan 02, 2009 | 1999 Audi A6
Power Steering
It maybe the cv joint or the bearing.
Dec 24, 2008 | 1996 Audi A4
2001 Audi A6
This is the indication for your windscreen washer fluid. If it is full and showing low on the cluster, then the sensor os bad in the bottle. Replace the sensor.
Dec 20, 2008 | 2001 Audi A6
Power steering audi a6 1999
First, I'd try refilling the fluid. You can't use fluid off the shelf - Audi uses proprietary power steering fluid, available at dealerships (probably a VW dealer can give you the same thing) or online at www.germanautoparts.com or www.ecstuning.com. Try refilling it. The power steering fluid is cooled by a cooler behind the lower part of the bumper, and the fluid itself cools the power steering pump. If you're low on fluid, the pump may be heating up and in turn, heating the fluid. Fill it to the proper level and keep an eye on it for a couple of days and see if that fixes the problem.
Jun 29, 2008 | 1999 Audi A6
Vehicle Parts & Accessories Logo
32 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
