Question about Dishwashers
Aeg favorit 40010vi
Beeps 3 times.
SOURCE: AEG Favorit Sensorlogic turbodry
I need to know manufactures year of AEG favorit 80860
Posted on Oct 29, 2009
reddyanantha
  • 205 Answers
SOURCE: My mums AEG favorit sensorlogic dishwasher has
please check the timer
Posted on Nov 06, 2009
SOURCE: Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
Posted on Jan 12, 2010
joe_lishman
  • 192 Answers
SOURCE: aeg favorit senorlogic three beeps and no evidence
Anti flood system triggered that puts the machiene in pump out mode. This machiene has a poor quality "Y" pipe at the bottom that is prone to pin holes in the pipe due to poor quality and extremely thin. The pin holes cause a small amount of water to activate the Anti flood micro switch on the polystireen float at the bottom of the washer.
Posted on Jan 17, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
Aeg favorit senorlogic three beeps and no evidence of problem but dishwasher won't work
Nov 22, 2009 | AEG 24 in. Favorit 40660i Built-in...
Jul 31, 2009 | Dishwashers
Feb 08, 2009 | AEG 23 in. Favorit 88070IM Built-in...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
AEG Favorit dishwasher fault
check time delay function - press til '0' appears or repeatedly til all time delaying diodes do not light
Feb 20, 2008 | AEG 23 in. Favorit 50750Vi Built-in...
Dishwashers Logo
Top Dishwashers Experts
