Question about Zanussi ZWF1430W Front Load Washer
How to cleen a washing machine filter without getting water on the floor
It is not picking up anything although just emptied and cleaned
Hi there, it's Jack at Dyson.
If your DC35 doesn't seem to be picking up as well as it should be, there may be a blockage in the floor tool, wand or bin inlet. The filter may also need a wash.
In normal use, we recommend washing the filter at least once a month using cold water without detergent. Allow at least 24 hours for the filter to dry completely before replacing it.
Our online support guide will walk you through each of the checkpoints needed to locate and remove any blockages: http://www.dyson.co.uk/support/dc35/dc35-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-wand
This should resolve the issue, but our experts are on hand to provide further assistance if you need it. You can reach us by calling the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 11, 2015 | Dyson DC-35 Digital Slim Cordless...
My dc 35 slim makes a whoowhoo noise and shuts off on its own
Hi Sharon, it's Jack at Dyson.
Like most Dyson cordless vacuums, DC35's digital motor is engineered to make a pulsing noise to let you know if something is stopping airflow from passing through the machine. This could mean the pre-filter is overdue for a wash, or that there's a blockage in the floor tool, wand or bin inlet.
To check for and remove any blockages, please follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc35/dc35-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-wand
In normal use, we recommend washing the pre-filter at least once a month as shown in the video below. Use cold water without detergent, and allow at least 24 hours for the filter to dry completely before replacing it in the machine.
I'm confident following these steps will resolve the issue and restore full performance to your machine. If you'd like some further guidance from our experts, you're welcome to give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 01, 2015 | Dyson DC-35 Digital Slim Cordless...
Not suctioning effectively
Hi Shari,
I'm sorry to hear you're having difficulties with your DC25. If the machine isn't picking up as well as usual, this may be due to a blockage - the filters may also need a wash.
The easiest way to check for and remove any blockages is to follow the steps shown in our online support guide:
http://support.dyson.co.uk/support/dc25/dc25-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
In normal use, the filters should be washed at least once every 3 months, as shown in the video linked below. Use cold water without detergent, and allow at least 24 hours for them to dry completely before replacing them.
http://support.dyson.co.uk/support/dc25/dc25-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/filter-washing-video
This should resolve the issue, but for any further assistance or advice, please call our Helpline free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.com
Jan 31, 2012 | Dyson DC25 All Floors Bagless Upright...
Clean pump light on how do i mfix
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Jan 30, 2012 | Whirlpool Washing Machines
Washing machine stuck in wash cycle, will not spin, will not drain
you will have to get the water out try dropping the waiste pipe low to the floor and see if you get any water out if not the you have a blockage ie filter / pump / sump hose
Nov 27, 2011 | Washing Machines
It doesn't empty the water from the bottom wondering if i need to clean the filter ?
Yes!
You should be cleaning the filter regularly anyway (Between 1 - 6 months depending on usage of the machine)>
If there is water in there now that wont empty, pull the machine out and tip it back 45 degrees sop you can remove the filter without the remaining water spilling out all over you and your floor
May 27, 2011 | Washing Machines
Put my washing on at a 60 degree wash for 1 hour 40 mins. Went back to machine several hours later, there was tiny amount of water on floor and machine had water in it but the wash had not progressed any...
Sounds like a blockage perhaps the filter needs cleaning or pump blades jammed...If its a Hotpoint then filter is middle of sump hose connected to the drum....
Jan 06, 2011 | Washing Machines
My whirpool duet washing machine is locked. The cycle doesn't get completed and indicates F02. We tried to unplug it, change ccyle and numerous times the pause-cancel button. How do I just get to...
The F/02 error indicates that your washing machine is not draining properly and thus taking too long to drain the water:
  • Check the drain hose and make sure it is not plugged or kinked.
  • With Power OFF: Check the drain pump filter for foreign objects: make sure you empty the washing machine water via the hose next to the pump filter cover first without flooding your floor! Incidentally, draining all the water will unlock the door.
  • If the above does not correct the problem, you will need to get the pump replaced.
Hope the information is useful: let me know how you go!
Sep 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWO/D 4605 Clean Pump light on, how do I
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
My Candy CNV 256 will not drain propery. I am
there is a pump filter at the front behind the kick plate . Turn machine off at wall . put towel's on floor remove kick plate with screwdriver carefully not to damage plate .remove screw from filter (if one is fitted )place shallow tray on floor under filter (baking )and carefully turn filter front there is always water in this part turn and pull gently water will now be filling the tray and towel's are getting wet clean filter and refit hope this works .post again if not
Feb 22, 2010 | Washing Machines
Zanussi ZWF1430W Front Load Washer Logo
20 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
