Question about Irulu 7 Inch Android 4.1 Jelly Bean Capacitive Multi-Touchscreen Widescreen 8GB Internet Tablet Dual Core 5 Point Touchscreen & Mali-400 MP GPU Tablet PC with RK3066 1.6GHz CPU 1GB DDR3 RAM WIFI HDMI With OTG Cable
AX922 START UP SCREEN PROBLEM - Irulu 7 Inch Android 4.1 Jelly Bean Capacitive Multi-Touchscreen Widescreen 8GB Internet Tablet Dual Core 5 Point Touchscreen & Mali-400 MP GPU Tablet PC with RK3066 1.6GHz CPU 1GB DDR3 RAM WIFI HDMI With OTG Cable
Tablet will power up but has no touch screen
Defective digitizer (a thin layer of invisible material placed just below the glass that senses the figure) in most touch screen devices.
Five things you should know before trying to fix smartphone or tablet...
Aug 07, 2016 | Tablets & eReaders
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
I require instructions for Irulu tablet Model AX922
They have a website, but they don't carry manuals. They do have videos. You could write.
http://www.irulu.com/Video
Aug 13, 2015 | Tablets & eReaders
Where can i download the drivers for ax922?
Go to the maker's online site. Look under help desk or they could have a listing of drivers.
Aug 02, 2014 | Tablets & eReaders
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
How to change irulu ax922 tablet battery replacement
The most Irulu tablets have 2 small cover screws on each side, pop the cover unscrew it and open with careful. the battery is connected inside its a square white plastic cover connected to the motherboard . Hope this help.
Mar 20, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
How to start may touch screen i am with ubuntu
You need to be running an OS that has touch screen enabled. http://forums.techguy.org/hardware/715186-enable-touch-screen-lenovo-x41.html
Dec 07, 2009 | IBM ThinkPad X41 Tablet PC
Irulu 7 Inch Android 4.1 Jelly Bean Capacitive Multi-Touchscreen Widescreen 8GB Internet Tablet Dual Core 5 Point Touchscreen & Mali-400 MP GPU Tablet PC with RK3066 1.6GHz CPU 1GB DDR3 RAM WIFI HDMI With OTG Cable Logo
Top Irulu Tablets & eReaders Experts
David Clark
David Clark
john smith
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
