Question about Canon imagePROGRAF iPF500 InkJet Printer
Recieving error 'printhead check nozzles' on an ipf500
3 Suggested Answers
SOURCE: error code E2813
This means that your canon printer has had a ink discharge and is covered up and there is ink laying on the sensor, The sensor if it has went out is 20 bucks you can find at a canon parts retailer
Posted on Jan 25, 2008
  • 413 Answers
SOURCE: nozzle check has even missing bands of color on new printhead
You will have to do an external clean of the print head.
Remove the cartridges.
Remove the print head from the printer.
Be careful not to touch the metal contacts on the head.
Boil some water, pour 1/4" (6 millimetres) of water into a saucer.
Immediately place the part of the print head 'where the ink comes out' in the water.
Leave in there for 2 minutes.
This will clean any junk out of the holes.
Place the head on some tissue paper and let the paper absorb the water.
Do not rub the print head with the tissues!
Replace the print head back in the printer, replace cartridges and run the setup - alignment.
This works most times unless the print head is faulty...
Posted on Jun 18, 2009
How do I fix error B200
"The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864"
Dec 01, 2014 | Canon PIXMA MP280 Photo Inkjet All-in-One...
PRINT HEAD ERROR
You can first try reseting your printer by unplugging all the cords for 30min. and then plug it back.
Please do a deep cleaning, align the print head, and also do a nozzle check.If you still have the problem then replace the print head.
Apr 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
How do i fix canon mp280 for error b200
Dec 01, 2014 | Canon MP280 All-In-One InkJet Printer
03130031-2F51
This is a printhead error
Remove the Printhead(s), clean the contacts,and replace in printer . Run nozzle check and try to print.
If you are able to print a few pages then get the same error, the Printhead will need to be replaced.
Good luck
Jul 10, 2014 | Canon imagePROGRAF iPF8000 Printer
Hp7580 printhead can I clean ink nozzle?
if you cane access the nozzle no problem then gentlly rub it with a toothpick soacked in alcohol to get off the pieces or a soaked qtip in alcohol and daub the nozzle
Nov 16, 2013 | Office Equipment & Supplies
I have just changed the Printhead on my Canon IPF500 and now it keeps saying 'detect poss err' Power off. But as soon as you power on again it goes to cleaning mode and then repeats the error. this is just...
You can try the head replacement mode ,take out the left head,clean contacts on the head and on the head board.Put the head back in ,and power up.
See if it solves the issue.If not ,than probably ,something else is going on ,or you just need a new head.What is the life time of the heads??
The purge unit sucks ink out of the head ,in a (one of the) cleaning cycle(s).Check the left head pad ,for dried ink.
As a precaution ,when taking the head out ,and cleaning the contacts in the printer ,disconnect the power cord from the mains.
If you need more help you can get ipf500 service manual from the below link:
http://goo.gl/ngye6L
Good luck
Aug 06, 2013 | Canon imagePROGRAF iPF500 InkJet Printer
Switch on and it displays "printer problem b200 refer to manual. The manual is useless what do I do
Unplug the printer for at least 5 minutes to see if it will clear that error message. The b200 error message is referring to the printhead overheating. It is possible that a printhead nozzle burned out while printing a page and ink ran out. No ink flowing through a nozzle can cause it to overheat and damage it. If waiting for the 5 minute power down doesn't do it, you may have to purchase a new printhead and also check to make sure that you have new ink cartridges.
Mar 02, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Printer will not recognize the new cartridge installed.
Solution
Follow these steps in the order presented to resolve the issue.
NOTE: If error messages also display on the computer, clear the error messages after each of the following steps. You might have to delete pending print jobs from the print queue on the computer to clear the error messages.
Step one: Perform a power reset
Follow these steps to reset the product. Make sure you connect the product directly to a wall outlet and not a surge protector or power strip.
Press the Power button ( ) to turn off the product.
NOTE: The product might not turn off after pressing the Power button. Continue to the next step regardless.
Disconnect the power cord from the rear of the product.
Unplug the power cord from the electrical outlet.
Wait 30 seconds.
Replug the power cord into the electrical outlet.
Reconnect the power cord to the rear of the product.
Press the Power button ( ) to turn on the product.
If these steps resolved the issue , there is no need to continue troubleshooting.
If the issue persists , see the next step.
Step two: Clean the electrical contacts on the printhead and inside the product
The ink nozzles on the printheads might clog if you expose them to air for more than a few minutes. The ink nozzles also might clog if you do not use the product for long periods of time. Follow these steps to clean the electrical contacts on the printheads.
CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical components.
Make sure that the product is turned on.
Open the top cover of the product.
Press and hold the OK button for five seconds. The carriage moves to the left side of the product. Release the OK button.
Wait until the carriage is idle and silent.
Unplug the product power cord from the electrical outlet.
NOTE: Do not turn the product off by pressing the Power button ( ). This causes the carriage to move out of reach.
Lift the printhead latch.
Lift the handle on the printhead that the error message indicates is missing or damaged, and then pull the printhead out of its slot.
Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead.
CAUTION: Wipe only the electrical contacts. Wiping the ink nozzles, located on the underside of the printhead, can damage the printhead.Do not touch the nozzles. Doing so permanently damages the ink nozzles, and the ink stains clothing.
Figure 3: Electrical contacts and ink nozzles
1 - Electrical contacts
2 - Ink nozzles
Wipe the electrical contacts with the swab until no ink residue remains.
Wipe the electrical contacts with a fresh cloth to dry them and remove lint.
After the electrical contacts on the printhead are clean and dry, place the printhead on a sheet of paper or a paper towel. Make sure that the ink nozzles face up and do not touch the paper.
  1. Use a fresh, dry, soft, lint-free cloth to clean the electrical contacts inside the product. Figure 4: Clean the electrical contacts inside the product
  2. Allow at least five minutes for the contacts to dry. Check the contacts for lint or debris, and then dry or clean the contacts again if needed.
  3. Plug the product power cord into the electrical outlet.
  4. Press the Power button ) to turn on the product. 'Printhead missing or damaged, replace the printhead' displays on the control panel.
  5. Insert the printhead into its color-coded slot. Press down firmly on the printhead to make sure the electrical contacts touch.
  6. Pull the printhead latch all the way forward, and then press down to engage the latch. If the error message indicates that both printheads are missing or damaged, repeat the steps in this procedure to clean the other printhead.
  7. Close the top cover of the product. The product restarts and then prints an alignment page.
Apr 05, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Does not print error b200
Helo, found on web. Good Luck :0)
Nov 07, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon iPF 8000: Hardware Error 03800500-2F2F and 03800500-2F30
it's a multiple problem....there is no enough ink for the head managment sensor to understand the good function of the print head.
Print a nozzle check to see what is going on
Then come back for more information
Feb 10, 2009 | Canon Office Equipment & Supplies
Canon imagePROGRAF  iPF500 InkJet Printer Logo
148 people viewed this question
old marine
old marine
