Question about Husqvarna Sewing Machines
As you sew thread bunches up in bobbin compartment
Thread bunches up in bobbin compartment
    Problem Solver:
  • 19 Answers
Generally, you need to rethread your machine on top. You should probably take the bobbin out and see if it is wound properly. You should change the needle too.
Posted on Feb 08, 2015
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
  • 19 Answers
SOURCE: Bernina Bernette 65 sewing machine
Presumably neither of you has or knows how to adjust your bobbin tension so, I'm going to presume it's your hook. Make sure you are threading the machine coorectly then you'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sits in) but make sure you note which way it sits inside your machine. Have a look at the plastic hook for any sharp edges or burs, you may need to replace your hook or try and gently sand (400grit) the plastic if possible. The key part of the hook is the small blunted point as this is what catched the loop of thread behind the needle. Please make sure that when you put your hook back in, that it is on the left side of that little guard sticking out on the lower right of your machine.
Posted on Dec 10, 2008
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
SOURCE: Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Posted on Mar 29, 2009
  • 30 Answers
SOURCE: mass bunching of thread in the bobbin compartment
it had nothing to do with the shuttle, it is the upper thread is not in the tensioner. lift the presser foot up and thread the machine even if you have to hold the thread on the top and pull on the bottom to make it go in the tensioner it will help, if a machine loops on the bottom it is the upper tension if it loops on the top it is the lower tension
Posted on Aug 22, 2009
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Thread bunches up when replacing thread on bobbin
If the thread is bunching or tangling when winding a bobbin, check that you have properly threaded the winder. Especially make sure you are running the thread through the bobbin tension assembly.
Aug 21, 2014 | Singer 5050 Mechanical Sewing Machine
I have a Singer Touch and sew 600e, the bobbin thread is all bunched up and machine jams up with thread. How can I fix this? Is there a simple setting that I am missing.
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is wound correctly
if these suggestions don't work, I suggest that you take the machine
to a sewing machine shop to have it checked
Aug 06, 2012 | Singer Sewing Machines
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
Will not sew
Check your bobbin compartment for loose thread and or debris. This often causes the thread not to combine properly. There is also a tensioner screw on the bobbin housing that can be tightened/loosened to adjust the tension, this may be the problem. Most machines have a removeable bobbin housing via clips or screws, to remove the assembly and clean.Or you can direct your queries to:
http://www.husqvarnaviking.com/us/2821_3079.htm
Mar 17, 2010 | Husqvarna Viking 1
Mass bunching of thread in the bobbin compartment
Aug 22, 2009 | Brother CS-8060 Computerized Sewing...
M machine stopped working properly. The lower thread is bunching, knotting and the fabric is being pulled into the bobbin compartment. The machine also makes loud noise. thanks
bunching lower thread is actually the upper thread not having enough tension due to mis-threading or wrong tension setting
Jul 02, 2009 | Sewing Machines
The fabric gets pulled down into bobbin compartment and thread gets all bunched up hard to remove
It sounds like your bobbin compartment might be pulled out of alignment. You might want to take the bottom plate off, clean off any lint and threads, and put the bottom compartment back in. Follow your manual if you have it. With your right wheel, slowly start to sew is the top or bottom thread having problems? You may have to rethread top and bottom. I found that one time, my top thread was not threaded correctly.
Mar 24, 2009 | Singer 6038 Mechanical Sewing Machine
Thread catching and bunching up in bobbin latch while sewing
I had the same problem where the thread was getting all bunched up on the underside. I took everything out and followed the manual concerning threading, then manually moved my right wheel to see if it would get bunched up. It took awhile, but I finally got it sew correctly again. I;m still not sure what was wrong with it. I have a singer 7470.
Mar 23, 2009 | Singer 132QRFB Mechanical Sewing Machine
When I start sewing my needle stops
You may be using a wrong bobbin size or you have lint ( fabric fuzz) clogging up the bobbin compartment. Take a pipe cleaner and clean under all the boobinholder sides to clean out. Sometimes even the bobbin getting wound from the spool can wind uneven and create this problem.
Nov 20, 2007 | Kenmore 756A-30BH Mechanical Sewing...
Sewing Machines Logo
44 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
