Question about Denon Dns1000 Table Top CD Player CD Player
How to clean your laser with alcohol and a Q tip
My playstation 1 wont read discs what should I do?
if your laser is still good, you can try cleaning the laser lens with a Q-tip and very little alcohol. enough to get the Q-tip wet, but not drip when you press against the lens. spin the Q-tip on the lens with the alcohol, then spin it again with the other tip (dry). this should solve your problem.
Aug 10, 2011 | Computers & Internet
My ps2 is getting a disc read error. It is the console, not the disc. How do I fix this? I've heard that you can clean the laser reader with alcohol wipes. Is this advisable, and if so, how should...
If it's the original, fat PS2 go here:
http://www.slideshare.net/Bravo77/ps2-repair-guide
If it's the newer, slimmer PS2.
To clean the laser lens, do the following:
Dip a Q-tip in rubbing alcohol (not dripping) gently place the q-tip on to the lens and gently twirl the q-tip.
Use the other end of the q-tip to gently dry the lens.
Hope this helps :)
Jul 16, 2011 | Sony PlayStation 2 (PS2) Console
Hi ! When I start to play a CD , it will only last for about 30 second , then it suddenly stop playing , what is the problem ?Grateful for help.
Either the laser is failing, or the unit is unable to move the laser along the sled.
Try skipping out to track 5 or so and see if it will play there for 30 seconds, or if it errors out trying to even get there.
If it goes to track 5 and keeps playing to the end, then you need to lubricate the chrome bar that the laser sled slides on. White lithium grease is what I recommend here. Remove the old grease first with a Q-tip and rubbing alcohol.
While you're in there, GENTLY clean the laser lens with a clean q-tip and rubbing alcohol.
Feb 24, 2011 | Audio Players & Recorders
Sometimes my Bose cd player works and sometimes it doesn't. Why? Where should I have it repaired?A
The problem is in the laser pickup, overtime the laser becomes weak and in some cases will skip or play the odd cd. It is possible the laser lens is dirty and needs to be cleaned, a Q-Tip and rubbing alcohol will sometimes bring it back to full operation. "if you can reach it" Dip the Q-Tip in the alcohol and very gently clean in a circular motion, use a fresh Q-Tip to dry off, if no change contact www.bose.com for customer support and ask for technical assistance, since this is a high end product it should be serviced by the people who make it because they have direct access to the parts.
Jan 22, 2011 | Bose Audio Players & Recorders
System plays games sometime and sometimes won't play any at all
try cleaning the laser lens with a laser lens cleaner for video game systems.
or, if you have easy access to the laser lens, use a q-tip dipped in rubbing alcohol (not dripping) to clean it.
gently place the q-tip on the laser lens and gently twirl it.
use other end of q-tip to dry it, gently twirling it.
hope this helps ;p
Nov 14, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 wont read the disc
your laser lens might be dirty.
gently touch the q-tip to the laser lens and gently twirl it.
or, you could use a laser lens cleaner for video game systems to clean it.
you can get one at walmart or target.
hope this helps :p
How to clean the laser
The laser it's self isn't what you want to clean - it's the lense. I recommend purchasing a CD laser lense cleaning kit from Best Buy. Usually the cleaner looks like any other disk, but it has a small cleaning cloth on it. You load the disk into the machine as you would any CD and the CD player tracks the laser and reader assembley to the position where the small piece of cloth is. As the cloth passes, it wipes the lense clean.
If you must clean the lense manually, I suggest using a Q-Tip and some isopropal rubbing alcohol. Dip the Q-Tip into the isopropal alcohol, and then press the swab of the C-Tip against the inside of the alcohol bottle to remove any excess alcohol from the Q-Tip so you don't have excess alcohol drip down into the laser assembley. CAREFULLY, GENTLY wipe the lense with the Q-Tip, using circular motion. After about 15 - 20 passes with the wet end of the Q-Tip, turn the Q-Tip around and wipe the lense with the dry clean end of the Q-Tip to remove any excess alcolhol and to prevent any residue that may accumulate as a result of the alcolhol drying. Again I stress being gentle because the lense rides in a magnetic field as part of it's focusing function and if you press the lense down too hard, you will damage the focusing coils and the unit will no longer be able to focus onto the disk and won't be able to read anything. Just be gentle, and good luck.
Oct 24, 2009 | Sony MegaStorage CDP-CX455 400-Disc CD...
Ps2 wont read disks it just goes to the browser ad configure screen how do i fix this?
Have you trided blowing at the back it might be dusty or ya spit on the dics, get a tissue and clean it.
Jul 29, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 wont read discs and we tried a disk cleaner
try a cleaning disc, if that does not work, the dvd mech is defective, try using some canned air to blow out debris from the worm gear assembly
Jul 27, 2009 | Sony PlayStation 2 (PS2) Console
None of my games will start up
try cleaning the laser lens with a Q-tip and rubbing alcohol (not dripping).
use the other end of the q-tip to dry it, again twirl it.
or you can use a laser lens cleaner for video game systems.
you can get one at Best Buy, etc.
also, make sure the disc is clean.
hope this helps :D
Jul 15, 2009 | Sony PlayStation 2 (PS2) Console
Denon Dns1000 Table Top CD Player CD Player Logo
65 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
