Question about Compaq (240762-001) Motherboard
Compaq motherboard serial numkber - Compaq (240762-001) Motherboard
My computer is compaq model no-SG34301L SERIAL NO-1NA8220G8C PRODUCT#KT477AA#ACJ, WHERE CAN I GET THE DRIVERS-VGA, SOUND, PCI, NETWORK ETC
Hi Sam,
have you tried the Compaq/HP website? There are usually a lot better answers there than you can find here. Go to Support and Downloads, you can usually input your model and it will let you know what is available for the machine there
Hope this helps
Joe
Aug 30, 2011 | HP Compaq Motherboard
MY COMPUTER IS COMAPQ MODEL NO-SG3430IL SERIAL NO-INA8260B6S PROD#KT477AA#ACJ I DIDNT GET THE DRIVERS CD FROM WHERE I GET IT FROM
MODEL NO-SG3430IL
SERIAL NO-INA8240JT1
PROD#KT477AA#ACJ
Sep 19, 2010 | HP Compaq Motherboard
Compaq presario sr1120nx will not post could this be the motherboard? i pulled out the memory modules and should have received beep codes for missing memory but none. Is this the motherboard?
yes if you have removed both sticks of ram and there is no beep code the n the motherboard is bad if you give me the serial i can give you the part number
May 13, 2010 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Need Serial Port Drivers
i would check the hp/compaq website there support is second to none i have Evan put the drivers into i Thailand imported laptop a friend of mine brought whilst on business in Thai and broke it when he got back to the uk. i just went online to compaq/hp and downloaded all the drivers.
Jul 23, 2009 | HP Compaq Motherboard
Compaq desktop pc serial no 6S2BLB5ZP1F0 mother board drivers
get a win xp bootable disk and install the o.s. it will automatically install the drivers of some devices. however, u must copy the bios version, and other devices found in the mother board, then download it through the net...
May 17, 2009 | HP Compaq Motherboard
How do I install a serial port to my Compaq Presario?
You will need to buy a PCI serial port card and plug it into a PCI card slot on the motherboard.
If your motherboard has a PCI card slot...
http://astore.amazon.com/dellebizcompu-20/detail/B000EDPY86
If your motherboard has a PCI Express card slot...
http://astore.amazon.com/dellebizcompu-20/detail/B000TQYY8O
Mar 27, 2009 | HP Compaq Presario SR2011WM PC Desktop
My friend has a Compaq presario f600 laptop & needs to replace the motherboard. What sort of motherboard would he need to get for it please?
I think I have the same laptop that also needs a motherboard. The Presario F600 also had a m/n of F572US found on the label with serial. Looking on the Compaq site I found the motherboard is the same as for the F500 notebooks which is 442875-001. Link is at: http://h10032.www1.hp.com/ctg/Manual/c01095493.pdf This number is also found under the memory chips on most Compaq/Hp Laptops. Simply open memory cover and remove the memory chips and there you will find the Motherboard replacement number. Good Luck!
Nov 03, 2008 | Computers & Internet
Compaq (240762-001) Motherboard Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
