Question about LG wm3001hwa front load steam washer 4.5 cu. ft. factory refurbished
No lights of front panel of lg washer - LG wm3001hwa front load steam washer 4.5 cu. ft. factory refurbished
Do I have to take apart the whole machine to fix the drain pump on my LG WM3455HW washer/dryer combo? I can't seem to find any instructions on this model.
Lucky You. The newer models of LG Combo units WM34xx have the filter on the right hand side and the pump can be changed through the bottom panel.
Nov 17, 2015 | LG Washing Machines
Lg front loader washing machine has no power
You will need to unplug the washer, remove the 4 screws from the white plastic pieces on the rear of the machine main top, remove the top by sliding to the rear, locate your main computer board in the top left, plug the washer into the wall, check for a small red LED light glowing on the board. You may have to unplug the washer again and remove the cover in front of the computer board to be able to see the light. If there is no red light your main control board is out, but this could have been caused by another failure such as a faulty stator, or rotor on the motor. Sometimes the connecting wiring from the front control panel to the main rear board will become loose and suffer damage against the moving tub. Best to have a qualified repair company check things out. Pleazer Appliance...
Apr 14, 2014 | LG WM-2277HW Front Load Washer
Does anyone know how to remove the top cover of the LG wm-2277 hw after the screws are removed from the back ? Have a water leak up toward the top of machine but cannot reach without removing the top ....
Disconnect the LG front load washer power cord from the wall outlet. Turn off the water supply to the washer at the water spigots coming from the wall.
Pull the washer 3 feet away from the wall, and disconnect the water supply hoses from the water inlet valve ports on the back of the washer. You may need a pair of channel lock pliers to loosen the hose connections.
Remove the screws securing the back of the top panel to the back of the washer with a Phillips-head screwdriver. Depending upon your model, you will have either two or four screws to remove.
Lift the back of the top panel up, and slide the top panel toward the rear wall, which will unhook the top panel from the clips securing the panel in the front of the washer. Lift the top panel off the washer and out of your working area.
Dec 27, 2017 | LG WM-2277HW Front Load Washer
LG WASHER WON'T Power on
Hello. If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 24, 2010 | LG WM1814CW Front Load Washer
Lg washer oe code pump pluged
open panel small door on left front panel. empty water and clear pump.
Feb 13, 2010 | LG Washing Machines
LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
Jan 31, 2010 | LG WM2455 Front Load Washer
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
LG Washer front loader stopped mid wash and is lock can't open door
unplug/plug unit. drain water via hose behind lower left panel on front.
Jun 03, 2009 | LG WM-0532HW Front Load Washer
LG wm3001hwa front load steam washer 4.5 cu. ft. factory refurbished Logo
14 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
