Question about Frigidaire FAA074S7A Air Conditioner
Timer light on unit will not run - Frigidaire FAA074S7A Air Conditioner
Amana Washer NTW4501XQ0. I have replaced the lid switch, and the timer. The washer still will not run thru an entire cycle. What should I try next
You can try recalibrating unit. With your dial setting at the 12 o'clock position on the timer, you want to do these steps within 7 seconds. Turn timer knob left one time, 3 rights, one left, one right.
Then you will see all the lights blink. ( no time constraints after you see lights blink) Turn the knob 4 clicks to the right, then push the start button. Let it run until you hear the lid unlock and you see the done light lit up. When you replaced the timer, you needed to recalibrate the unit.
Feb 25, 2015 | Amana Washing Machines
I have a Heavy Duty Westinghouse 3-Outlet Outdoor Digital Photocell Timer and the time keeps running slow. Does the unit need sunlight to run the clock or do I need to change the internal battery? I have...
1) No the timer has internal rechargeable battery.
Battery is not replaceable.
2) I test timers, 4-6% arrive defective. Most go bad within few years. Some last long time.
3) If you set timer to turn ON at dusk, and turn OFF 2 hours later, then reflected light or car lights can give photoeye feedback so timer thinks it's light. Timer turns off and resets. I don't know if this information applies to you.
4) Link shows timer and manual for Westinghouse
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any
do-it-yourself project.
Jan 13, 2011 | Heavy Duty Westinghouse 3-Outlet Outdoor ...
Air con not working. Operation and timer lights flashing, then operation light flashes and then lights go off. Air con is blowing air but the outside unit is not blowing any air.
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Dec 31, 2010 | Fujitsu Heating & Cooling
Comprresor not running, light not on
check defrost timer find on unit and turn manualy and see if it starts running . some times they get stuck. if it happens again replace unit....
Aug 12, 2009 | Refrigerators
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
York mini split unit has power but will not come on stand-by.
york split ac indor unit no working .timer light is on . how to stope timer control light ?
Jan 12, 2009 | Frigidaire FAA065M7A Air Conditioner
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Lights are on in my maytag fridge freezer but it is not running it is silent
1 or 2 things if nothing is running at all then the timer is faulty or thermostat if the unit has mechanical timer you can advance it by hand and it should run and like i said timer or thermostat
Oct 15, 2008 | Maytag Refrigerators
Whirlpool EHT 141JK 'fridge
failedcompressor start relay or bad commpessor
Apr 02, 2008 | Refrigerators
Frigidaire FAA074S7A Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
