Question about JVC AV-32D305 32" TV
Our JVC tv suddenly turns off and then it turns on again.....
... then off, then on, etc. It makes a sort of electrical "zorch" sound each time.
    President:
  • 814 Answers
Http://maps.jvc.com/cAscList/ This is a web link to the JVC customer support website for local JVC service centers. The web site also has the factory service centers if your television is still under warranty. The television is having problems with intermittent component failure and needs to be tested and evaluated by a service center. The service center will have all the service information and parts to repair your television. If you are not under warranty you can ask for a estimate of the repair cost plus shipping and handling to figure out if the television is worth repairing or not. Find the service center nearest to you and give them a call, tell them the model number of your television and explaine the problem you are having with the television. Try to get a estimate of the cost of the repair over the telephone. This estimate may not be accurate as they cannot tell what is wrong with the television unitil the actually open it up and test it. They might be able to give you a ballpark figure. I hope this information helps you understand the problem your television is having and helps you solve that problem. Thank you for using FixYa and have a nice day!
Posted on Jun 20, 2009
Tv won't turn on
I think its a defective convergence chip/circuit and need a tech to replace it. It could cost about $300 or so.
Nov 04, 2007 | JVC AV-56P575 56" Rear Projection...
After a power failure / electricity tripping my JVC Lt-39N510 LED TV has no power. The display light does not come on. I switch off the power button on the side, take out the plug. After two days, I plug...
Check and replace its main power regulator board. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 05, 2014 | JVC Televison & Video
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
When I turn the tv on, it sounds like static electricity coming from the back.
Check its final anode connection for arcing. You have to replace the final anode rubber boot, if arcing is here. Seek tech support. This is a dangerous work, for an un-experienced one.
Jun 22, 2012 | JVC Televison & Video
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
JVC AV-F29MX3 I was watching a film on my DVD connected to the TV, when suddenly the screen turns black with no sound heard. Also the front light indicating 'ON TIMER' and 'ECO' started blinking in red...
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective .................. so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective.......... price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore ( 09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact jvc service centre.........
Apr 21, 2011 | JVC AV-F29MX3U 29" TV
Car died while driving. Electrical seems fine.
check to make sure the catalytic converter is not clogged, the timing belt won't make a noise when it breaks, check to make sure you still have compression. if this doesn't help get back to me and we'll do some other tests, please rate my fix i strive to be the best,Thanks Ray
Apr 20, 2009 | 1995 Honda Civic
Jvc 48" tv model av-48wp34
Sounds like you lost the High Voltage. The beating sound is the power supply trying to start up. After a predetermined time it will quit to protect the set. This is a very common problem and typically not that much to repair. If you are not an electronics repair technician you should find a reputable repair shop and enlist their services. I would not think the cost should exceed $150.00 to repair. Good luck.
Jun 18, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-32D305 32" TV Logo
182 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
