Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
How to remove the housing, front of the bissell cleaner from the back of the cleaner to get to the heater
How to remove the front of the Bissell cleaner from the back after removing the top of the handle.
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Posted on Sep 20, 2008
SOURCE: schematic parts diagram for bissell proheat 9200 carpet cleaner
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
hopes this helps, they also have parts, but shop around.
Posted on Jan 08, 2009
whytfang
  • 170 Answers
SOURCE: bissell manual
Sorry this is as close as I could come...but *** covers the Quicksteamer 1970 model...and surely it is the exact same process for yours...as this manual covers several models.....I found it at www.bissell.com.....I hope this helps...good luck and thanks For rating my effort....The Fang
http://www.bissell.com/images/UserGuides/1770_0206.pdf
Posted on May 20, 2009
heatman101
  • 43501 Answers
SOURCE: Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
My Bissell Pet Carpet Cleaner brushes will not turn around and heater doesn't work?
Hey you may want to check out our website for assistance in troubleshooting your machine. Here's a quick link to the FAQ page.
http://www.bissell.com/faqs/?cid=ccsocial
Jan 01, 2013 | Bissell 1770 Quicksteamer II Upright...
How do i get the lower handle cover off so that i can get to the water heater on my bissell proheat 2x model #9200?
on the back just above the unit there are two holes that are long and skinny and have a screw(phillips).there is also a small screw on the back of where the cord comes out.you must also remove the other screws higher up on the back(these screw into the front plate of the machine) warning,the heater is not in the handle as some have shown online.unscrew any of those that look like they attatch to the front face.there is also one behind the lower hose holder(pull it off and you will see the screw
Nov 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat used does not put out water
The spring your talking about goes where the trigger switch is. You need to dismantle the entire unit to access this, remove 6 screws on hood, two main handle screws, two tool caddy screws and finally two lower back housing screws. Removed top handle and gently open unit up
Aug 29, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell proheat won't spray water. I need to
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
eygfd
Jun 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell Powerbrush cleaner quit working. The
found it from Tara put online in nov 2008 Thanks this is it
Had the same problem... although I don't have particularly hard water, the heater block corroded just enough to stop most of the flow after about 4 years. Disassemble the handle to get at the heater block (3 pairs of screws/bolts), remove the tubes with needle nose pliers, use a paper clip to knock out the corrosion on the front tube on the heater block, flush with a syringe to get rid of any other bits of corrosion (some extra plastic tubing connected to the back tube of the heater block helps here, and catch the water from the front tube to prevent water in the electronics...), reassemble (avoid disconnecting any wires...) and try it out. Worked for me! I REALLY have to thank the person who suggested this fix! THANKS!!!
I used regular pliers , phillips screwdriver , the pointed end of a compass and a turkey baster full of water to blast it out . You have to improvise . Take your time watch the little rubbers on the heater make sure its not hot . It was just the inlet gets pluged up in the heater . You have to take off the tools then its the bottom set of plastic not the handle . You can test by pushing the plunger at the top . You must take the handle off . Loosen the pieces it just came off for me then snaps back on . This is all it was for me , very simple . I am disabled and did it on a extra old carpet a little at a time over a few hours . For someone healthy its a hour job tops or less . Just be patient . God helps those who help themeslves and asks for patience .
Mar 15, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Carpet Cleaner pro heat- water doesnt come out
The screw that is located in the center of the handle, that holds the assecory hose holder must be tight. My screw was missing, put one in and cured the problem. Sounds stupid but it worked. Got this idea off the Bissell web site. Also if you have a pump belt it may need replacing.The cover is on the side of the machine. Go to the Bissell web site and look up by your model # and name of machine. There are several quick fixes that you can do yourself. Why pay for expensive repairs when the Bissell site will help you for free. Good luck.
Jun 28, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bissel Proheat Carpet cleaner
My Bissell had the same problem. The hand attachment does not use heated water. So I Found a clog of calcium and dirt in the heater portion of the unit. The heater is in the handle behind the red heater light on the front. Remove the upper portion of the handle. Remove the lower two screws in the lower portion and the parts will split apart. Remove the hoses and remove the heater. (mark where the wires go) The bottom of the heater can be removed with a screwdriver. The tubes leading into the heater is where the clog was but there was a lot of debris inside Make sure to clear it all and the hoses as well. I put it together and it works great.
Nov 23, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
How to replace pump for 7901 bissell pro heat steam cleaner
unplug unit first
take six screws out of housing.
lift of housing.
you can see pump at front of machine.
four screws hold pump in.
make sure all tubes are routed correctly.replace housing,
make sure no tubes are trapped
Jun 04, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
