Question about IBM System Storage TS2240 Ultrium Tape Drive
Lto-4 error code e - IBM System Storage TS2240 Ultrium Tape Drive
IBM LTO3 error code 5
Hi Ray
Error 5 on the front panel usually refers to a read write error of some description.
First of all try a (not expired) cleaning tape and then try a backup on a BRAND NEW LTO tape.
If this does not solve the issue then your drive probably needs a repair and service due to a worn or badly calibrated head.
LTO Repair service UK Based All manufacturers of LTO drives repaired
Mar 14, 2014 | Computers & Internet
Canon ir 2230
Hi Sharma
I think you might need to review this question, The Canon IR2230 does not use LTO Data tapes.
Refurbished Tape Drives Stock List for download Refurbished LTO drive
May 13, 2013 | Imation 17533 Storage media - LTO Ultrium,...
LTO1 error code 4
The LTO 1 error code 4 means "A firmware or drive problem has occurred."
You might try reflashing your firmware, which you'll find here.
I hope that helps.
Mar 14, 2011 | IBM (08L9762) LTO 1 Tape Drive
Our dell powervault 122t shows error code A0
Error Code A0 - Error occurred during carousel movement (Position Not Found). Could be caused by a missing or misaligned cartridge carrier, or an obstruction, or unexpected cartridge in either the carousel path or Import/Export slot.
Remove the power cable and SCSI cables then try open the top cover. Check and see if there are any tape blocking or obstructing the movement. Sometimes it works sometimes it doesnt. I have 5 of these devices, few of them were replaced as its not working anymore due to these codes and as they are pretty obsolete, its not worth to repair them anymore.
Feb 03, 2011 | Dell PowerVault 122T LTO (pv122tlto)...
MY IBM TAPE STICKED INTO THE DRIVE TAPE AND I CAN'T GET IT OUT
Hello dude !
You have no other choice but to remove it manually  ie theres a problem with the mechanism .
I t can't come coz sometimes the tape is btw the read head and the pinch rollers .
good luck
Oct 03, 2009 | IBM LTO Ultrium 4 Tape Cartridge - LTO...
I am unable to get IBM UlTrium TD4 SCSI device drivers for windows 2000 server
if you "have not" using Backup Software (e.g. Symantec Backup Exec, CA), you can try this IBM LTO-4 driver for Win2K.
IBM LTO-4 Device Driver for Windows 2000
Ned Huang
Tandberg Data Taiwan
Technical Support.
Oct 15, 2008 | Computers & Internet
Ultrium LTO 3 Tape Autoloader Error
what software are you using? try not backing up the system state to see if that changes anything?
Feb 07, 2008 | HP StorageWorks ESL712e Ultrium (AA934B)...
IBM System Storage TS2240  Ultrium Tape Drive Logo
48 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
