Question about Bosch 714" 15 Amp Circular Saw CS20
Replace blade guard on bosch cs20 circular saw
How do I get the blade guard off?
  • 313 Answers
SOURCE: finding the lock button..changing a
older model of circular saw dont have a spindle lock.wedge the blade on a bench vise & make sure ur not clamping the teeth of the blade & then turn the blade screw clock wise.
Posted on Aug 09, 2008
muttandjeff
  • 359 Answers
SOURCE: how to lock blade on older circular saw
ONE WAY IS TO TAKE A PAIR OF VISE-GRIP PLIERS ,LOCK THEM ONTO THE BLADE VERY TIGHT WHEN THEY TURN UP AGAINST THE BED OF THE SAW YOU SHOULD BE ABLE TO REMOVE THE BOLT THAT HOLDS THE BLADE WORKS WELL DID IT LOTS ( bear in mind some of the bolts are left hand threaded so if does not go one way try the other )
Posted on Nov 24, 2008
rowdy45176
  • 2176 Answers
SOURCE: Lower Blade Guard on a Miter saw
If you haven't fixed them yet, give me the model and brand and I will see what I can do. Dave
Posted on Dec 24, 2008
jj505
  • 195 Answers
SOURCE: My Bosch CS20 circular saw's blade guard is sticky
Take to a compressed air hose and blast away sawdust,if greasy spray with mineral spirits,let dry.
Please rate. Thank you. jj505
Posted on Mar 30, 2009
  • 597 Answers
SOURCE: how do I install the blade on a bosch cs10
Their web site seems to be down at the moment but most circular saw you just need to lock the blade somehow. Sometimes putting the blade up against a piece of wood so it can't turn will get the job done. Unplug the saw so it can't run. Some saws come with a custom wrench to turn a custom bolt, others a regular combination wrench would work. There should be a bolt that goes into the center of the blade. To keep the bolt from coming out while cutting, they are reverse threaded so you loosen it by turning the bolt the reverse direction you on a normal bolt. take the bolt out and be careful you don't loose the washers on each side of the blade. Put in new blade and reverse the process of taking it apart.
Posted on Dec 03, 2009
How to pull out Bosch CS20 circular saw's armature?
There are several steps:
Remove the base height adjustment lever assembly(#56,57,71,72,73,74)
Remove the lower blade guard (#37)
Remove the brushes (#810)
Remove the upper guard housing (#827)
The armature will usually slide out with the upper guard - once out wiggle the armature out of the guard housing.
Reverse order to reinstall
http://www.ereplacementparts.com/bosch-cs20-0601674057-circular-saw-parts-c-128_1138_9632.html
Dec 20, 2016 | Bosch Saws
Blade guard on my bosch pcm 10 mitre saw does not open?
Could there be a piece of wood caught in the guard?
Jan 07, 2015 | Bosch Saws
How do I fix my spring loaded lower blade guard on my circular saw
I need to know the make and model of your saw in order to help you.
Jan 05, 2015 | Saws
How do you remove the blade guard on a bosch cs20?
counterclockwise in the same direction as the little arrow you show as the sawblade turns around. if you look at your handle look near that you will see on the metal part of the motor house a metal ,a 90 degrees bent metal bracket which protrudes, pust on this and turn slowly the sawblade then you feel on am short moment and push it as far as you can then its locking the blade , then you turn the bolt counterclockwise and The bracket itself bounces back.
Aug 25, 2013 | Bosch Saws
How to replace a makita circular saw guard
Simple, unpug tool. Remove blade and back flange. Remove circlip and lift off guard. Unclip spring. Re-fit new guard. Refit spring and circlip. Refit blade.
Aug 18, 2013 | Makita Saws
Circular saw blade rubs on the guard
remove the blade and check for the inner flange that should be behind blade. also there might be a ring underneath the inndr flange. or check to make sure the flange is installed correctly.
Apr 05, 2010 | Ryobi Saws
How to replace a guard spring on a model 367 skilsaw
take blade off and under blade there is a giude around shaft area around housing where sping goes i hope this was helpful
Aug 28, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Jun 20, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Bosch 714" 15 Amp Circular Saw CS20 Logo
94 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
