Question about Hampton Bay 73554 Antigua Ceiling Fan
Ihave four wires that connect to the chain switch and the wire harness is numbered one thru fourwires aregray purple brown and black
5 Suggested Answers
TBlessed 1
  • 61 Answers
SOURCE: ceiling fan wires
is the old fixture still installed?
Posted on Oct 17, 2008
SOURCE: 3 speed switch 4 wires where do they go????
corrected by trial and error
Posted on Feb 11, 2009
wiringlunati
  • 576 Answers
SOURCE: I am replacing the three speed pull chain switch
You may just have to guess and try it. As long as the L is right, you'll be fine. My guesses, however, would be 1-brown, 2-gray, 3-purple. I don't have a wiring diagram, those are just based on years of wiring. Good luck and have fun experimenting.
Posted on Mar 24, 2010
MN_Jack76
  • 45 Answers
SOURCE: fan switch was removed from the fan. I have 4 wires for the switch. 2 brown, 1 gray and 1 black. On the switch it has the letter L numbers 1, 2, 3 on it which wire goes on which number?
This is a bad situation. Ceiling fan 3-speed switches are not universal and neither is the wiring codes. I always make sure to right down the color codes and where they plugged into the switch before removing wires. I can maybe narrow one down but will assume no responsibility. L stands for line and is usually power into the switch, which is normally black, but not always.
Posted on Mar 23, 2012
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
Trying to install kenwood kcd mp238 cd player into a 1996 Ford Expedition. I need to know wiring data to connect the wires of cd player to harness, which colors should I match wires up to, so I can just...
Black Ground, yellow, battery, red switch battery, blue not used, blue white power antennea/amp, brown tel mute, white black front left neg, white front left pos, gray black front right neg, gray front right pos, green black rear left neg, green rear left pos, purple black rear right neg, purple rear right pos
Oct 24, 2012 | Car Audio & Video
Four wires (black, brown, purple & striped) going into O2 sensor and three (two black one white) coming out...how do they connect?
Year make and model ?
The sensor probably has a heater, so one black is for the heater and the other may go to the computer.
Jul 03, 2012 | Cars & Trucks
Installing aftermarket stereo in 99 silverado which wires from stock harness connest to aftermarket harness
connect the wires as indicated below
1999 Chevrolet Silverado C1500 Wiring, aftermarket stereo wire colors
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (Tape off) not used
Car Stereo Dimmer Wire: Brown (Tape off) not used
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
Oct 22, 2011 | 1999 Chevrolet Silverado 1500
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
I have a fairly old panasonic car stereo/cd changer. i just need the wiring diagram for it. what color equals what? i typed in the model number but nothing turns up. . . i had to replace the old system,...
Here is the Colors of the Cars factory harness
Constant 12V+ Red Switched 12V+ Red/White Ground Black Illumination n/a Dimmer Orange/White Antenna Trigger Yellow Antenna Right Front Front Speakers 3 1/2" Dash Left Front (+) Green Left Front (-) Green/Yellow Right Front (+) Purple Right Front (-) Purple/Yellow Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Brown/Yellow Right Rear (+) Blue/Red Right Rear (-) Blue/White
And Here is the Chart for the radios wiring
Red 12V+ Switched power
Grey Right front speaker +
Grey with black stripe right front-
White left front +
white with black stripe l/f -
Purple R/R +
Purple with black stripe R/R -
Green l/r +
green with stripe l/r -
Black ground
orange illumination
yellow constant power
Apr 07, 2010 | Car Audio & Video
1998 Suburban Fuel Pump wiring harness replacement. On the vehicle are 4 wires in the harness, Black/Gray/Purple/heavier Gauge Black. A mechanic in the past spliced a replacement harness as - heavier Black...
if its the correct harness then yes... i would follow colors.conecting the thinner black to the orange/black.
i have built and repaired wire harness' for four winds rv for 5 yrs now and previously gm cars for 4 yrs
Apr 27, 2009 | 2003 Chevrolet Suburban
Hampton Bay 73554 Antigua Ceiling Fan Logo
41 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
