Question about Panasonic Lumix DMC-LZ7 Digital Camera
Camera got dropped now it won't turn on.
My camera got dropped on the lense while it was off. I tried turning it on right away to check if it was still working and nothing! I tried again this time the shutter opened and nothing on the screen came on. It's been 3 weeks now and I have no idea what to do. The lense is jammed open and it won't turn on for anything.
  • 244 Answers
The only way to sort it properly is to dismantle and reassemble. Because it has sustained damage you will have to check for any internal damage caused by the drop. Now the lens is jammed open would suggest the guide pins have either come out of their slots preventing movement or something is obstructing them.
Posted on Jun 20, 2009
    Brigadier General:
  • 4,090 Answers
Make an insurance claim
Fuji finepix won't connect to computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 17, 2012 | Cameras
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
Turn the power off and on again
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
I have a sony DSC-W170. It was dropped and now
I had exactly the same problem with my Sony Cyber_Shot. Here is what I did and the problem was fixed. I cleaned around the lense. While I turned the camera off, I pressed down the lense very softly (some up and down motion). After a couple of times, the lense retracted almost completely. Then I pressed a little harder until the lense retracted 100% as normal times. I turned it on everything was back to normal. If the lense does not have mechanical problem, you should be able to do what I did.
If there is no mechanical problem, most likly some dirt got on the sides of the lense while it was open. Try keep it very clean always.
Good luck;
Jun 15, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
S630 won't turn on
Openings the lense is the last thing you want to try. If you dropped your camera, you may have to. If you did not drop your camera, some dirt somhow got on the sides of the lense and they prevent your lense from closing or opening 100%
Try this first
turn it on and the same time pull the lense out. Your lense may not be open all the way out. OR
Clean the side (outside) of the lense. While turning your camera OFF, push on the lense in NOT too hard. Try that a few times, If the lense retracted 100% or near 100%, just push the lense in a little harder untill it is 100% retrected. Turn it on, It may work now.
Good luck!!!!!!!!!!
Good Luck!!!!!!!
Jun 11, 2009 | Samsung S630 Digital Camera
Lens will not retract on Sanyo VPC-T850, 8.1 megapixel, digital
Did you drop your camera? If yes you either damaged the lense mechanical parts. If some dust or small particle are on the side of the lense, it may prevent the lense from opening up. If the lense opens up and down a little bite try to pull it out by have very softely. If it opened fully, clean up the outside of the lense and turn your camera a few times. If it does not have a mechanical problem, it should be back to normal. If above did not help, the lense has to be taken out and inspect for broken or damaged parts and clean it and put it back on the camera.
Good Luck!!!!
Jun 10, 2009 | Sanyo VPC-S880 Digital Camera
Camera won't power on. Lense won't retract.
Pls check the batteries are they supplying full power to camera are they aged or old try replacing them with good power batts and Memory card try re formatting it on a PC card reader
lense is coming out at full length or there is a grinding noise or abnormal behavior in it pls check may be u dropped ur camera or any other incident broken its lense gear.
pls check and reply me for more help
Feb 27, 2009 | Olympus FE-220 Digital Camera
'Turn camera off and turn back on' message
TRY DROPPING THE CAMERA -- YOU HAVE NOTHING TO LOSE!
I was heartbroken to learn that my Lumix DMC-TZ1, which I purchased 2-3 years ago, had died -- right during my daughter's dance recital, for seemingly no reason. Tonight I was surfing the web researching replacement cameras (many brands), and I realize that I feel like there is no real "history" on the camera that's any worse than any other camera on the market, including the Canon Powershots, which are all the rage right now. So I started researching on the Fixit site other cameras for possible problems.
What I found is that all the cameras have funky messages (Sony and Canon included!) that result when he camera has been dropped or the lense has somehow been altered. So I read all the different "solutions" and then came up with my own:
I decided that the lense needed to be un-jammed. At this point, if the camera was useless to me, I might as well take a chance and try to unjam it. So I did!
I held the camera about 3-4 inches from a table top. Then I simulated a "drop" (without the case) that was gentle enough that it wouldn't smash the LCD but that would maybe make the lense unjam. (Note: I couldn't SEE any problem with the lense; this was just a hypothesis I couldn't go wrong trying.)
Each time I put the camera on, tried to modify the zoom (a function which normally makes me get the error message forcing me to turn the camera off), and then got the message. BUT the 3rd or 4th time: TA DAH! NO MESSAGE! INSTEAD, A SHOCKER: I WAS ABLE TO MODIFY THE ZOOM! AND THEN I TOOK A PICTURE! AND VIDEO!!!!
So my camera is back! And I also have discovered that the flash problem I had started to have previously has now seemed to have gone away also.
My advice is to just TRY! You have nothing to lose: try "dropping it" back into shape! I know it sounds crazy -- but I just saved at least $200 by doing this!
Mama Maria in Burke VA
Sep 17, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-LZ7 Digital Camera Logo
178 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
