Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Cool tech 34134z how to remove freon from storage tank
2 Suggested Answers
mhkamran
  • 180 Answers
SOURCE: I have a Robinair 34134Z It will not recover freon
Please check the following: 1# Check the recovered amount of refrigerant since the last filter change(Max.filter cap.150 LBS/68 KG).If more then this you must change spin-on filter & vacuum pump oil.2# Check with vacuum gauge on compressor test(During compressor running) port & make sure it has 13"HG of suction,If suction less then 13''HG then you have to replace the compressor.3# Check all tank hose (Vaipor,Air purge & Liquid) is connected on the ISV tank quick seal.(Do not over tight).Hope this will solve your problem.
Posted on Dec 29, 2009
Where is the drain for the air conditioner
Are you getting water in the floor?
Jul 15, 2014 | 2004 Dodge Stratus
How to replace tank fill solenoid on robinair 34788
No, you cant remove tank fill solenoid until close low (Blue) and high (Red) side valve on ISV tank (Internal storage vessel). see attached picture to identify Tank fill solenoid. 39b3bb9f-14fe-4040-a186-3a3a23d2848e.jpg
Jun 18, 2014 | Robinair Cool Tech 34700Z Recovery,...
34700z only charges about .5 lbs to 1.0lbs, asks to start engine to help draw freon in. still won't charge any more. where should i start
The machine requires a min amout of 6lbs to even charge. but if you are showing any amout charging it is not the machine its self. you are looking at may be bad hoses or couplers. it is common in the winter months to have charge issues if the unit is not above 70 degrees F. dont forget there are cars/trucks out there that no matter how hard you try you can not complete a charge on the high side and you must switch over to a low side charge
Aug 06, 2012 | Robinair Cool Tech 34700Z Recovery,...
How do I recalibrate scale on Robinair 34134Z
Robinair Model-34700Z scal calibration follow as bellow:
Press main menu then press up or down arrow till scree appear ''CHANGE DEFAULT'' then press 5454 from the keypad & then YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & then press YES key. now follow the on screen text. Once you calibrate scale then press STOP key to exit.
NOTE: You should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE'' or any other setting it must be on factory setup.
Hope this will help you to solve the problem & if my solution is useful to you please vote for it
Apr 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
Hi, I have a robbin 34134z indicates high pressure and do not work. At times it works and then stops working. I can do? . I live in Venezuela and here there is no Robinair agent indicated as repair them. I...
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# May the ISV tank is not overfilled,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid for proper operation.Hope this will solve your problem, Best of luck & vote for my solution!
Nov 25, 2010 | Robinair Cool Tech 34700Z Recovery,...
The freon is coming out at the oil/dye tank when performing a recharge???
IT'S SOUND LIKE NEED TO REPLACE OIL DRAIN SOLENOID OR OIL DRAIN SWITCH ( SENSOR). IF BOTH ARE REPLACED
Sep 20, 2010 | Robinair Cool Tech 34700Z Recovery,...
Cool Tech 34700Z Recovery, Recycling, Recharging: when I have the system in a vacuum the liquid freo...
I don't think your machine have any problem! But if you are sure then you can rebuild oil drain solenoid.
May 17, 2010 | Robinair Cool Tech 34700Z Recovery,...
HI, I HAVE A ROBINNAIR 34134Z AC UNIT. I AM NOT ABLE TO ADD 134 TO SYSTEM PUSHING KEY PAD ARROW UP. POUNDS REMAIN AT 0.0. ON ALL OTHER FUNCTIONS, KEY PAD WORKS FINE.( UP--DOWN). REMOVED COVER, REMOVED AND...
Please try the following: 1# Verify the ISV (tank) dose not have excessive pressure.note the tank's temperature & pressure readings and compare to pressure chart on unit.purge excess air if necessary.the refrigerant may be contaminated and should be handled appropriately.
2# Press recover & verify the Recovery solenoid (S1) is receiving power & opening properly.
If not receiving power check continuity of the wiring between solenoid & circuit board,repair as needed.
If the wiring is correct and no power is being applied to the solenoid,replace the circuit board.hope this will help you.
Jan 11, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a Robinair 34134Z It will not recover freon It has 22HG suction The solenoid is working properly Auto freon goes back through the valves to the solenoid and the suction pulls 22 hg at the solenoid...
Dec 29, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
