Question about GE (PSS26MSRSS) Side by Side Refrigerator
My GE TFX20JA SIDE BY SIDE REFRIGERATOR ,HAS PROBLEM
Frozer side on back panel has to mani ice and other side not have 42 F, now 52, no OF ini time vorking long time not stop,
  • 527 Answers
Sir/Madam,
Basically did you defrost all the ice and frost with a hair dryer and reassemble the unit? Things should run normally for a few days if you did so and then the ice will build up once again. You have one of those GE units with a electronic control board and what is known as an adaptive defrost system. It is difficult to diagnose without technical literature and knowledge of those units. In my experience the most common problems with those units is the defrost heater shorting out.
Also likely a defective defrost timer motor.
check these 2 links and go through it
link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Jun 20, 2009
Ge tfx20ja refrigerator
Does the compressor run? Or run intermittently? Are there any clicking sounds? Possibly the start relay is bad. It's a small box attached to the compressor. There should be 4 letters after the model number that you'll probably need to get the correct part.
I'd give these folks a call: http://www.partstap.com/searchresults.aspx?model_or_part=TFX20JA
Jul 01, 2013 | GE Computers & Internet
I have a 15 year old side by side ge profile refigerator. The floor of the freezer constanly freezes order and leak under the freezer side, What is the cause?
LOOK IN SIDE THE FRZ ON BUTTEM BACK WAY LOW BACK THER A DRAIND AND IS PLUG UP OR FROZER NEED TO UN PLUG TRY TO USE HOT WAER AR A HOT STEMER TO UNPLUG DRAIN.
Feb 21, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator when it shuts down it makes a clunking sound,i have a tfx20ja.thank you.
Good day,
That is one or more centering springs that either weakened or broke inside the compressor itself.
Only a pro would be able to correct it by replacing the compressor. Very expensive.
However, these compressors can run a long time before they totally fail.
May 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Cold at bottom only side by side fridge/freezer ice maker frozer over just before problem started
Sounds like a defrost problem. Look inside the freezer. Look and see if the back wall, behind the food is has ice or frost on it. If so you most likely have a defrost problem. With these models it is most likely bad defrost heaters. You can take the inside pannel out of the freezer, use a hair dryer and defrost (DO NOT USE SHARP OBJECT TO BREAK ICE) Put pannel back in and it will operate normaly for about 3 or 4 days. Until you can get the part or get it fixed. This way you will not loose you food.
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side By Side not cooling on refridgerator side.
Look on the back panel inside the freezer for ice beginning to show. Most times when this happens the fresh food section is the first to notice. Your refrigerator has a control board on the back. If not defrosting the air flow to the fresh food section is greatly reduced. Let me know, Sea Breeze
Jul 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE clean steel side by side not freezing ice. See
Unplug the fridge and pull away from wall. There is a panel on back that has a control board. Look on both sides for burn marks or loose welds. Also remove bottom paper panel on back and lets see if compressor is running. Let me know what you find, Sea Breeze
May 19, 2009 | GE GSL22JFR Side by Side Refrigerator
Side X side TFX20JA refrigerator not freezing or maintaining cold
Thank you for your help!! I was able to repair my refrigerater thanks to someone who had previously had the sam problem and was given three things to check. The problem was the heater in the freezer was burn out.
Jan 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side with ice and water in door
This is a problem with my GE side by side also. It only happens occassionally and there doesn't seem to be any fix. I've had GE repair service here more than once. It seems that the insulation in the door is insufficient to keep the water line from freezing up. Small wonder GE is part of this awful financial mess.
Dec 17, 2008 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Frost on back wall of the fridge
unplug thye unit and let it thaw out. the frost that you are seeing has the coil frozer up underneath the panels.
Nov 22, 2008 | Samsung RS2556 Side by Side Refrigerator
Replacing the ice maker mechanism on a GE side by side
  1. Unplug the refrigerator.
  2. Remove the icemaker's front cover by unscrewing or prying it off as needed
  3. Remove the ice bin, shelves, and vertical partition.
  4. Remove remaining screws, disconnect the icemaker wires from the harness connector or socket, and remove the unit from the freezer.
  5. Remove the back access panel and any fasteners that hold the inlet valve to the refrigerator.
Jul 06, 2008 | GE GSS25SGMBS Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
83 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
