Question about Casio Fx-115es-s-ih Adv. Scientific Calculator -Fx-115es-s-ih-
How to solve for vertical motion - Casio Fx-115es-s-ih Adv. Scientific Calculator -Fx-115es-s-ih-
How to solve horizontal lines on a CRT TV monitor and what could be the possible courses for it
Monitor horizontal lines problems usually caused by a defective vertical output/driver ic. A missing supply voltage to the vertical output ic may caused similar faults which is one horizontal line across the display. Dry joints and missing vertical output pulse from vertical oscillator ic also could contribute the same symptom. If you discovered that the protection resistor (usually from 1 to 4.7 ohm) open circuit or burnt, then replacing it won't solve the problem. The resistor burnt or open circuit was due to a short in the vertical output ic. Thus you have to replace the vertical output ic and the burnt resistor together before you switch on the monitor.
Jun 12, 2015 | Televison & Video
Mitsubishi VS-4543
is that wavy in vertical motion? and bending?  in that case maybe you have low voltage in your power inlet! or can you specify the color of wave and motion, if horizontal or vertical?
Oct 16, 2007 | Mitsubishi VS-45607 45" Rear Projection...
I have a Fab-U-Motion with stitch regulator that I use with a Husqvarna embroidery machine. It works fine for regulating the stitches when I move horizontally, but when I try to do vertical motion...
There are two devices on the underside of the carriage that reads the movement. It sounds like on of them is not touching the base so that it can read the movement.
Dec 14, 2017 | Sewing Machines
How do you adjust headlights on a 1993 chevy C1500
if you look at the light, there is an adjustment screw at the top of the light that controls the up and down motion , clockwise will raise the beam, and a screw on the side that controls the side to side motion. the best way to center your lights would be to park the vehicle 25 feet away from a verticle wall. be sure to be very square to the wall and on level ground. make a tape line vertically on the wall in very close relation to the center of the vehicle, and another tape line vertically in very close relation to the center of each headlight. now place a tape line horizontally in very close relation to the center of the headlights. start with low beam adjustment. adjust the high intensity zone to 2 inches below the horizontal line and 2 inches to the inside of the vertical line directly in front of the headlight. for high beam adjustment, adjust so that the high intensity zone is centered on the center vertical line and just below the horizontal line. hope this helps
Apr 04, 2010 | 1993 Chevrolet C1500
I have a LCM 17v8 LCD Monitor purchased in 2007. There are ribbon like movements constantly on the screen which is in constant motion as if the screen is painting.
in your monitor check vcc to vertical ic it should 12v if not present then check regulator ic 7812 if faulty replace it problem will be solved
Mar 05, 2010 | Computers & Internet
Trying to adjust head lamp in a 1995 chevy C1500 just had to buy a new lamp assembly
Oct 20, 2009 | 1994 Chevrolet C1500
Vertical line across picture tube on my Symphoic model WF2703.
Is it just folded over with a thin line of light thru the middle of screen. It is a vertical collapse. Vertical Ic is loosing connection with the board or failing Already. resolder first then see if it can actually solve it. If not check capacitor or neighboring components within vertical circuit or replace the vertical IC and check if this solves the problem.
If your not inclened in electronics, have it service by a qualified one.
May 14, 2009 | Televison & Video
Line across middle of screen.
The line of color is due to a failure in the vertical circuit. The main suspects are the vertical Ic AN15525A and/or capacitor c308 220uf@35volts
If you have the capacity to do so, you should check the other electrolytic capacitors in the vertical circuit which are USUALLY located near the vertical IC in most cases
you can purchase the part at
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5760279&smodel=CT32SL15N
or mcm electronics
Mar 13, 2009 | Panasonic CT-32SL15 32" TV
Brother sewing machine
There is cluch on the handwheel that connect motion,try to tighen this If negative,There are two small bevel gear (hard PVC )connecting to the upper crankshaft where the handwheel was connected.This transmit motion when motor run, most commonly the vertical rod where one bevel gear was connected maybe broken or viceversa at the upper crankshafting that holding the bevel drive gear is broken try to check this.
Mar 06, 2009 | Brother LS-2125 Mechanical Sewing Machine
Screen has vertical lines in the display
either the power supply or the main board (eca).
Sep 21, 2006 | ASK Proxima Proxima DP2000X Multimedia...
Casio Fx-115es-s-ih Adv. Scientific Calculator -Fx-115es-s-ih- Logo
10 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
