Question about Denon DRM-740 Single Dual Cassette Deck
Deck is running too slow - Denon DRM-740 Single Dual Cassette Deck
  • Denon Master
  • 1,267 Answers
The unit either needs a new belt, Capstan bearing oiling as in taking the flywheel out and if this does not fix it a new capstan motor. The motor is adjustable with a small screw driver provided you have the appropriate wow and flutter meter and test tape to do the job.
Posted on Sep 29, 2015
Why is this turntable running slow?
It depends which type of turntable it is. If a belt one then change the belt, make certain you make a note of how the belt fits before removing it.
Direct drive turntables are more difficult. As it could be any number of faulty parts that cause it.
A build up of grease or dirt in any type of deck can slow the speed down.
A faulty motor on both types of deck will also cause it.
Sep 07, 2015 | Audio Players & Recorders
Why is my tape deck running slow
Hi there! There are five general causes for cassette tape machines to run slow 1) motor faulty Check the motor governor electronics 2) Belts and rubbers worn or slipping 3) Lubrication of mechanism bushes 4) Cassettes binding in their cases this is quite common 5) If there is a solenoid or motor that do the work of the moving of capstan roller then there can be something wrong with that it can be binding on the sliding mechanism
Sep 16, 2014 | Audio Players & Recorders
My Horizon CT 7.0 treadmill slows down when i step on it
LUBE THE deck belt and rollers bearing . This happen because you must lube about 150 miles aprox. See the video and fix it. However if the problem persist. Time to replace the old board deck.
God bless you
Jan 25, 2013 | Horizon CT7.0 Motor Control Board
Elite ef 9213 treadmill slows right down but does not stop after 3 minutes
LUBe the deck belt inmediately in according with the instruction manual maintenance, you have some deck belt worn. 2) Inspect the drive belt for replace.
RUN THE SOFTWARE CALIBRATION for diagnose and troubleshooting.
sincerely. God bless you
Apr 28, 2012 | Exercise & Fitness
Engine slows down with blades are engaged?
sounds like the blade spindles are binding, many have Zerk fittings to grease them. with belt disengaged try turning the pulleys they should turn easily and have no wobble in them. if either is wrong replace spindle and best to change in sets. this is the most common issue.
Apr 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Slow tape speed on reel to reel tape deck
My TC-230 has the same problems and it is mechanical. Actually, its real hard to say what your problem is, but it is most likely the pinch roller is to tight on the piece that is connected to the motor. This extra tension is from a spring inside the machine and, when in storage for a long time with the machine set to stop, extra pressure builds up on this spring. Try leaving it unplugged on fast forward/play overnight. that might help.
May 08, 2009 | Audio Players & Recorders
Tape deck running slow
Does this happen with all tapes?
Jan 18, 2008 | Audio Players & Recorders
Motor plays at a very slow speed
capstan belt may be failing. check this by removing lid and touch the capstan flywheel when running. if it is easily stalled/slow to come up to speed and or the belt slipping badly then belt will require replacement.
Oct 14, 2007 | Sony TC WE435 Stereo Dual Cassette Deck...
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
