Question about Whirlpool Ovens
Oven won't turn on
Fault detected
  • Whirlpool Master
  • 5,323 Answers
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
2.
3.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Posted on May 18, 2015
2 Suggested Answers
  • 1196 Answers
SOURCE: Oven won't light, "F1" fault
The problem is with the touch pad, the touch is defective, it is shorted and will need to be replaced, Replace touch pad or clock assembly (also called the ERC) which is the touch pad, once this is replaced, the problem is solve.
Posted on Jun 13, 2011
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Fault code Close door (S) keeps coming and oven won't start
The oven is telling you that the secondary switch is not working. Either the switch is broken or the door or switches are out of alignment. the switches cost about 4 dollars. Not an expensive repair by any means.
Sep 09, 2012 | TurboChef TORNADO Electric Oven
Oven just beeps when i turn it on
Hit stop clear then reprogram oven If that won't work unplug for a short time plug back in and see if this works. It found a fault code in the oven control and if you can't reset it. You will have to order a new one. Go to managemylife.com if you need to download manual
Dec 09, 2011 | Kenmore Ovens
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
I had to pull my oven out of the wall and ever since I did that, I get a message that says "Feature Not Available" on any button I hit. Is there a reset button or something?
It's an error code that will not go away until a technician resets it. Quote straight from the manual :
"The oven may detect a fault during programming or during operation. If a fault is
detected, the message "Fault detected - press power to clear" or "Fault detected -
press enter to try again" may appear. Follow directions in the display. If the fault
reappears or does not clear, call an authorized servicer or the toll-free number in the
display.
If the same operation is attempted before having the wall oven repaired, the message
"Feature not available" will appear. The feature will remain inoperable until service
is obtained":
Mar 15, 2011 | Jenn-Air 30 in. Pro-Style Electric Single...
After oven turn on and heat up and reach temperature short thereafter unit goes into F1
F1 means the system watchdog cicuit has detected a fault.
Try pressing CANCEL for 30 seconds if it continues after that you will probably need a replacement control board.
Dec 13, 2010 | Dacor Ovens
What does f3 mag mean on the display?
F3: Magnetron Current Low
Fault is displayed when the current transformer
(CT) on the I/O control board does not detect
enough current. The fault is monitored when the
microwave is on during a cook cycle or self-test.
The fault is cleared from the display at the onset of
a cook cycle if the CT detects current or when the
magnetron is successfully energized in Test Mode
Sep 03, 2010 | TurboChef TORNADO Electric Oven
Fault has been detected
I'm afraid I can't help you but if you go to www.jennair.com and sellect support they should be able to.
Jun 21, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Touch pad on double oven shows code F7
Electronic control has detected a fault condition. Press STOP to clear the display and stop the
beeping. Reprogram the oven. If a fault reoccurs, record the fault number.
Jul 07, 2009 | Ovens
My Frigidaire FGF354BGWC flashes F1 and beeps
Electronic control has detected a fault condition. Turn the Temperature Control Knob to OFF,
and disconnect the power to the range. Wait 30 seconds and reconnect the power. If fault
recurs, disconnect the power and contact an authorized servicer.
Dec 17, 2008 | Frigidaire FGB24L2A Gas Single Oven
Open Questions:
Ovens Logo
60 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
