Question about Pool & Spa
Neatrol Systems NS6000 Spa Controller
Hello - I have a Neatrol Systems NS6000 Spa Controller and the lock button/light is on. I am unable to unlock the device to turn the spa on. Please advise on how to unlock.
  • 7 Answers
SOURCE: No heat for the spa.
go to the heate and see if it tries to start and report back on any noises you hear or click or fans or is you smell gas
Posted on Jan 06, 2009
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
PartsCenter
  • 125 Answers
SOURCE: Jandu Aqualink Pool/Spa Controller RS6
AQUALINK GUIDE BOOK
  • 44 Answers
SOURCE: just bought house with aqualink pool spa, one of
You cannot drain the spa using the indoor controller, unless the valves out at the equipment are set wrong. go to the outside pannel and put the system in" service mode"(using the button on the left). then push the button on the right till it says "spa fill".There are 2 "accuators" (or automated valve turners) They are black rectangular boxes connected to the water valves. Use the toggle switches on the side to turn the vales to the correct positions. You want the pump to **** from the pool and return to the spa. Now turn on the filter pump and let it run till the spa is full. Put the system back in "auto mode" and you are done.
Posted on Oct 29, 2010
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
The Date and Time change back to installation date and programs no longer work
if you have a 4 button spa side remote unplug and see if it continues its called ghosting if so replace controller
Dec 10, 2012 | Jandy Aqualink RS8 Pool/Spa Combo Control...
How do I unlock the control panel on my spa?
Here's a link to a list of ways to unlock the control: http://spapartsshop.blogspot.com/2012/02/spa-control-panel-unlock-codes.html
Those guys should be able to help.
Nov 25, 2012 | Hydro Quip Inc Pool & Spa
Jandy rs6 all button stuck in spa mode
take off front cover of controller sometimes the buttons stick if ok need new display board
Mar 17, 2012 | Jandy AquaLink RS2/6 All Button Dual...
I have a 1999 Emerald spa that uses the Balboa controls. I recently took my 2 pumps to a motor specialist to rebuild them. I have installed them and now it seems like they do not work on the high speed. ...
Understand that this information isbeing provided as-is and without warranty or guarantee. As with allelectrical components and devices, all work should be performed by a licensedspa or pool technician. Serious injury or death can occur if a component isimproperly repaired or installed. This soundslike it could be an issue with the board but there is some testing that needsto be done to determine the actual cause. A spa technician will be required tocome out and verify the wiring to the pump and then typically start testingvoltages off of the board as the unit switches between the relays that controlthe speeds on the pump. You can find answers to common spa orbath problems online at http://www.balboadirect.com/support.aspx Hope that helps!
Apr 24, 2011 | Balboa Instruments Duplex Digital Panel 2...
How do i unlock my hotub i moved into a new house and it came with but i cant figure it out
You need to clarify -
What is locked?
Spa Cover latches. Most of these are 1 of 2 types
1. Uses a plastic key from the front that simply turns to secure the spring latches. coastsider_0.jpgIf you do not have the key, then use a screw driver to twist the lock 180 degrees. squeeze the 2 lower clips on either side and press upward to release the latch. Repeat on the others. If you need a key, we can provide this one for $2.00.
In this design, the latch anchor has a blank face. If this is the type you have and you are missing the key, you will need the key to release the latch. We can provide you a key for $2.00
Topside Spa Controls -
I do not think these models have any lockout feature on the topside control. The controls are manufactured by Balboa Water Group. If you are seeing some 2 character codes on the display, please provide that information here so we can further assist you.
Nov 25, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Just bought house with aqualink pool spa, one of our teenagers pushed the buttons, we dont know which one and the spa has emptied and the pool is full and we dont know how to get the water back in the spa...
Oct 28, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I have an aqualink RS6, when i press the waterfall button, the display reads locked out. how do I remove the locked out
If your trying to turn on from a inside or spa side controller, then most likely the main control panel is either in time-out, or service mode. When the main controller is in either of these modes it locks out the other controllers. This is designed so if a service tech is working on the system, a user cannot turn something on. Try looking at the main controller and look for a mode button. It will toggle between, auto, time-out, and service. auto is normal operation, time-out should suspend the system for about 3 hours, and service mode suspends the system indefinitely until the mode is changed.
Sep 19, 2010 | Pool & Spa
Pool & Spa Logo
47 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
