Question about Exercise & Fitness
What are the advantages of electric circuits - Exercise & Fitness
What are the Advantages & Disadvantages of Electric Vehicles?
Electric vehicles like battery powered cars and ATVs are the future of transportation technology. They are emission free, energy efficient and convert renewable energy into motion. But they do not attain high speeds like their internal combustion engine counterparts. Here you can read all advantages and disadvantages for Electric Vehicles - http://www.polarisind.in/blog/the-advantages-disadvantages-of-electric-vehicles/
Jan 27, 2014 | Polaris ATV
What are the advantages of manual toothbrushes over electric toothbrushes?
The main advantage of manual toothbrushes is the cost. They are much cheaper than electric toothbrushes. Whereas an electric toothbrush can cost you $50-$100, manual toothbrushes can be bought for just a few bucks. Another advantage is that manual toothbrushes come in different sizes and colors, so there's a larger variety to choose from.
Feb 04, 2013 | Health & Beauty
Wiring a 3 wire photo electric cell
Open following link for photo-cell wiring illustrations:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#photo-eye
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electric circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 03, 2011 | Intermatic K4221C Photo Cell Control 120 V...
Replaced thermostat, replaced heating elements, replaced wiring to electric box, water heater still does not work
Take 20 minutes and do complete troubleshoot.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Things to look for are:
1) sediment inside tank shorting out lower element.
2) wire broken or shorted between parts
3) thermostats not wired correctly
4) water heater not getting 240V from circuit breaker, so water heater tests for 120 and appears to have electricity, but circuit is not complete.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Mar 03, 2011 | Whirlpool Water Heaters
Major cirsuit breaker blew and partial loss of power in residential home ...is bus port still good? Looks good. replaced breaker and working again..will this last?
1) If busbar looks good it probably is good.
Usually when bus is bad, it has burned appearance, and looks like it is ready to crumble or is crumbling.
2) Problem with bad busbar, we sometimes add subpanel next to main box.
Buy subpanel box Home center or electric supply.
Square-D subpanel shown on following page came from electric supply.
http://waterheatertimer.org/How-to-install-a-subpanel.html
3) You can also add tandem breaker to main box.
Tandem breaker fits over one bus finger, but is actually two separate breakers.
Then double-up two lightly used circuits so you have room to move breakers around.
See image showing tandem.
http://waterheatertimer.org/images/ap-235-breakers.jpg
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Feb 16, 2011 | Electric General Ted134050 50a 480v...
When I flip the manual switch it clicks but the lights wont turn on.
Manual override should turn lights ON-OFF even if timer has gone bad.
It sounds like problem is electrical.
Suspect line-up:
Test that timer is getting electricity from breaker.
Burned out bulb. Change bulbs. Spray WD-40 on bulb threads before installing bulb.
Outdoor wiring can go bad easily, outdoor bulb sockets become dirty and stop functioning.
Loose wire between breaker and timer -or- between timer and lights.
Loose wire inside timer box. Tighten screws.
Loose wire on circuit breaker. Tighten screw on circuit breaker.
Tripped circuit breaker: click circuit breaker all the way one direction and then all the way back other direction.
Bad circuit breaker. Move wire from one breaker to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Jan 20, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Norelco Advantage 6756 X Electric Shaver will not hold a charge, is there a replacement battery?
You will find the correct battery for model 6756X at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To change batteries, start by removing the lotion cover on back. Then remove screws on the back to take off the battery compartment cover and access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Jan 17, 2011 | Norelco Advantage 6756 X Electric Shaver
Battery replacement on a Norelco Advantage shaver
You will find replacement batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To change them you will first need to remove the back cover. Do this by opening the lotion compartment on the back and then removing the screws on the back. Remove the back to reveal the inside of the shaver. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If this is not something you can do yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Sep 18, 2010 | Norelco Advantage 5615 X Electric Shaver
Exercise & Fitness Logo
65 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
